110 Fencing Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 09-17-2009, 09:58 AM   #1
Unhappy
110V fence lighting
Help,
I need help with fence lighting, the problem is I think, I have 2.5 inch end post and 2 inch post I'm trying to find high voltage fence lighting to go on the post. I'v looking everywhere and all I can find is 4 inch post. Could I do low voltage lighting and still be able to see in my backyard? What other options are they?
TWINLADY is offline   Reply With Quote
Old 09-17-2009, 11:28 AM   #2
How much illumination, in foot-candles, do you want in your backyard?
http://www.cp.berkeley.edu/SCIP/Marc...e/Lighting.pdf
How high are the posts?
Old 09-18-2009, 11:17 AM   #3
Rewards Points: 126
By high voltage, you mean 120 volts right? Yes, you can use 120 volts for outside/landscape lighting. But for your safety, I would suggest you use a pre-fabricated low voltage landscape lighting kit. This way you only need to plug in the transformer, then string out your lights. Check a lighting store. They can help you decide what will work best for you. Good luck.
If it worked before you worked on it. You did something wrong.
Does All Solar Lighting in Back yard really work? KUIPORNG Landscaping & Lawn Care 11 05-27-2008 02:36 PM
lighting a covered, enclosed patio (cross-posted in electrical) 1655graff Remodeling 1 11-21-2007 12:45 PM
lighting a covered, enclosed patio 1655graff Electrical 5 11-21-2007 08:06 AM
lighting guideline's - kitchen remodel dcd22 Electrical 3 08-01-2007 11:50 AM
