110 And 220V Plugs Stopped Working. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-05-2011, 08:45 PM   #1
hohadcr's Avatar
Rewards Points: 346
Question
110 and 220V plugs stopped working.
Everything was fine during the day, but tonight, a couple of plugs quit working. This is an old house with some old wiring.
1. 3 110V plugs in the kithen stopped working.. They are probably in series.
2. The stove plug in the kitchen stopped working at the same time.
3. Tested the dryer. Dryer works fine.
I checked the panel box, no breaker was tripped. I flipped the breakers to the plugs and to the stove plug off and back on, still not working.
What can be the problem?
Thanks in advance.
hohadcr is offline   Reply With Quote
Old 10-05-2011, 08:55 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Do you have a dryer?
Check any other 240 volt circuits
Also check all the 120 volt circuits, you may have a missing leg.
jbfan is online now   Reply With Quote
Old 10-05-2011, 09:14 PM   #3
hohadcr's Avatar
Rewards Points: 346
Checked dryer. It works just fine.
All other 120v ciucuits are fine. So, a missing leg?
Old 10-05-2011, 09:26 PM   #4
jbfan's Avatar
Rewards Points: 650
If the dryer is working, and all other 120 circuits are ok, then you are not missing a leg.
Old 10-05-2011, 09:28 PM   #5
Rewards Points: 330
ARRG! me thinks he thinks you are cap'n AHAB..just kidding.poster says dryer works.no missing leg.look for gfci.may have had one installed by previous owner?
oleguy74 is offline   Reply With Quote
Old 10-05-2011, 09:44 PM   #6
hohadcr's Avatar
Rewards Points: 346
There is no GFCI plugs in the house. then.. what's wrong?
Old 10-05-2011, 09:52 PM   #7
Rewards Points: 330
volt/ohmmeter.start opening boxes and start testing.
Old 10-05-2011, 09:55 PM   #8
jbfan's Avatar
Rewards Points: 650
You need a volt meter to check the output of the stove receptacle.
An old house could have the receptacles pulled from one leg of the stove.
The Following User Says Thank You to jbfan For This Useful Post:
oh'mike (11-02-2011)
Old 11-01-2011, 10:44 PM   #9
U get 220 from two legs of 120 (I know guys most of us know that). If you loose one of the legs you would loose your stove and any outlets on that leg. being an old house it is possible that they made the lost 120 outlets parallel with one leg of the stove (not smart or code, but it has been done). You probably have an open either at the stove or in the line leading to it. It is VOM time starting at the breaker then trying to physically follow the wires from there.
Good Luck! I have been there.
Jim
JimLee_Sr is offline   Reply With Quote
Old 11-02-2011, 05:05 AM   #10
dmxtothemax's Avatar
Rewards Points: 5,608
Thanks in advance.
Is there a breaker marked in the fuse panel
for the stove outlet ?
Maybe some one has added the three outlets in the kitchen
onto the same circuit as the stove outlet !
Although this is not proper,it is possible.
Is the stove outlet 110v also ?
This would explain both failures !
you might have a loose connecttion or a burnt out wire !
Where is the question ???
You will have to follow the wires from the fuse panel !
dmxtothemax is offline   Reply With Quote
Old 11-02-2011, 05:30 AM   #11
DIY staff
Rewards Points: 7,174
She never said that the stove was a 220v line---Is it?
Old 11-02-2011, 06:08 AM   #12
kbsparky's Avatar
Dryer runs, but does it heat? The OP could be missing a leg, and the dryer would appear to work .... but no heat ...
-KB
The Following User Says Thank You to kbsparky For This Useful Post:
bob22 (11-02-2011)
