110/220 - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2013, 05:35 PM   #1
putting in a new goodman air handler with only air condition 1.5ton unit,,is it wired to be 220?
buck545 is offline   Reply With Quote
Old 05-20-2013, 05:48 PM   #2
eastcoastsparky's Avatar
Rewards Points: 150
Wat does the nameplate say?
eastcoastsparky is offline   Reply With Quote
Old 05-20-2013, 06:13 PM   #3
Rewards Points: 150
it is not wired 220. It could be wired for 240 . you really need to look at the nameplate rating.
usair is offline   Reply With Quote
Old 05-20-2013, 07:11 PM   #4
208/230 volts......60 hertz.....1 phase
Old 05-20-2013, 07:13 PM   #5
Post
no heat kit...circuit 1 ...h.a0/0........mca 3/3.......mop15/15
Old 05-20-2013, 07:53 PM   #6
Idiot Emeritus
Rewards Points: 1,492
208/230 means any voltage from 208 (a common commercial/industrial voltage) to 230 (the common household voltage).
These voltages are plus or minus 10%, so the actual operating voltage can be anywhere from 187 to 253.
In your case, you'd use a two pole 15 amp breaker. Not more than a 15.
If you're using NM cable (Romex), a 14/2 will work just fine up to around 100'. If it's longer, use a 12/2.
Mark the white on both ends near the terminations with colored tape (any color other than gray, white or green will do, most of us use red), or color it with a felt-tipped marking pen.
Rob.
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
mm11 (05-20-2013)
Old 05-20-2013, 08:51 PM   #7
thanks for the help
Old 05-20-2013, 09:25 PM   #8
jproffer's Avatar
Rewards Points: 716
jproffer is offline   Reply With Quote
Old 05-20-2013, 09:45 PM   #9
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Just curious, and this is a serious question: If the name plate says 230V, why would you think it would be wired for 120V (110)?
Old 05-20-2013, 10:41 PM   #10
Electrical Enthusiast
Rewards Points: 504
Maybe the 208 volts on the nameplate confused the OP.
Kyle_in_rure is offline   Reply With Quote
110/220 electric motor jburd964 Appliances 1 12-22-2012 09:03 AM
Emerson electric motor wiring, is it dual votage? 110/220 thewmas Electrical 3 02-04-2012 05:16 PM
Surface Mount subpanel and 110/220 recepts - good idea? vsheetz Electrical 4 11-15-2009 10:29 PM
