Old 02-10-2013, 08:08 PM   #16
" Euro " electrician
frenchelectrican's Avatar
is it 110 or 220
Originally Posted by jlmran View Post
But a 240 volt single pole circuit and a 240 volt double pole circuit are each intended for specific equipment/devices.
Just becarefull when you mention 240 volt single pole circuit breaker the only time you will see that in North Americianie side is 240 volt corner grounded delta system only .,, That is it own world and it is easy to get confused with this one.
But over here in European area it is common to find 240 volt single pole circuit due it is our normal single phase supply ( 240 volts line to netural ) but few case I know in Germany but very limited over here in France we can have 240 volt delta ( line to line or 127 volts line to neutral if in wye format )
However this part will get your attetion when you mention double pole which also it is normal due we will have switched netural ONLY at the OCPD ( breaker or RCD <GFCI> ) that is common with single phase per our French Nomes ( codes ) but the other type of double pole is line to line format which it will result 415 volts ( part of three phase supply )
Merci,
Marc
The Following 2 Users Say Thank You to frenchelectrican For This Useful Post:
JohnnyB60 (02-10-2013), mpoulton (02-10-2013)
Old 02-10-2013, 08:17 PM   #17
is it 110 or 220
A 240 volt only device (has two wires not including a ground wire for connection to 240 volts) will work on any 240 volt source of the correct AC frequency, regardless of whether that is a 3 phase source or a 120/240 volt U.S. residential feed or a 480 volt industrial system with neutral to provide 240 volts.
A 120/240 volt appliance has three connecting wires not counting ground: hot, hot, and neutral. Its power switch must be double pole to switch both of the hot wires since the power is not officially switched off if any two of the three connecting lines are not interrupted. (An appliance could have a triple pole power switch to interrupt the neutral as well as the two hots but this is not needed and rarely if ever seen.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
Old 02-10-2013, 08:18 PM   #18
is it 110 or 220
Merci,
Marc
Hey...the Internet abolishes all borders. We are all on the same planet.
jlmran is offline   Reply With Quote
Old 02-10-2013, 08:20 PM   #19
is it 110 or 220
Originally Posted by joed View Post
Yes but if plug a 240 hot to ground device into a 240 hot to hot device then you may have just applied 120 volts relative to ground onto the metal framing of the device.
Clothes dryers excepted, in a word, no
Anti-wingnut is offline   Reply With Quote
Old 02-10-2013, 08:20 PM   #20
is it 110 or 220
Allan.,
Check the underline part majorty of the USA and European industrial users use three phase and there is no way you can get 240 volts out of 480 volts Wye system which it is common one.
The only correct voltage from 480 volts three phase with netural is 277 volts not 240 volts ( the key word is square root of 3 that how you get that number )
Merci,
Marc
Old 02-10-2013, 09:09 PM   #21
is it 110 or 220
I meant a single phase system with center tapped 480 volt transformer secondary which system (subsystem) I believe might be found in a factory although the service to that building is not single phase 480 volt..
Old 02-10-2013, 09:25 PM   #22
is it 110 or 220
The centre tapped 480/240 volt transfomer is not a super common item but it do show up once a while.
But majorty of them used 480 volt primary and 120/240 or 120 volt single phase secondary which that is most common way to use them.
Otherwise few location I know I dealt with them they will use 480D-208Y120 transformer which that is common as well. ( on triphase supply )
Merci,
Marc
Old 02-10-2013, 09:33 PM   #23
UAW SKILLED TRADES
Stubbie's Avatar
is it 110 or 220
Originally Posted by JohnnyB60 View Post
I don’t know what you are talking about by 240 volt double pole circuit. Double pole usually means opening both sides such as a contractor or rely. I think you're maybe referring to a 3 wire circuit where you have two lines with 240 volts between them and a neutral wire for 120V.
Nope in my case I was refering to our split phase system in the USA where you have two ungrounded conductors with a 240 volt potential between them and an equipment ground. Which most likely is what the OP ordered if it was for use in the USA.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-10-2013, 09:45 PM   #24
is it 110 or 220
Originally Posted by Anti-wingnut View Post
Voltage is voltage whether it is between two hot poles or hot and ground
I have wondered about that. Is that true; will everything intended for one work on the other? (obiously 240/120v won't work on straight 240v, but ignoring that).
Toller is offline   Reply With Quote
Old 02-10-2013, 09:45 PM   #25
Close to retirement
is it 110 or 220
Ok we call that a 2 wire 240 volt circuit. We also normally refer to it as Lines (1&2) because that is how they are listed on wiring diagrams and on the terminals.
Poles are only refered to when speaking of Breakers, Switches, Contacts. Relays or disconnect switches although the terminals are identified by Line 1 and Line 2. I know that technicality they are poles from the generator producing them, but it gets confusing.
JohnnyB60 is offline   Reply With Quote
Old 02-10-2013, 09:47 PM   #26
Close to retirement
is it 110 or 220
What! 240/120 does work on straight 240, you just don't use the neutral.
Old 02-10-2013, 10:26 PM   #27
UAW SKILLED TRADES
Stubbie's Avatar
is it 110 or 220
That's true L1 and L2 are commonly used to identify terminations of a 240 volt circuit.
However we are talking about a cord and plug which will likely not be identified that way but it is irrelevant.
The OP stated that she purchased something from china, she didn't say she purchased it here in the USA. MY take was she ordered something thru a chinese source. MY point is that China uses 220 volts plus a neutral, in the USA we use 120 volts and a neutral or if you prefer it would be more proper to say 120 volts and a grounded leg. China is 50 hz USA is 60
Stubbie
Old 02-10-2013, 10:37 PM   #28
Field Service
is it 110 or 220
What's confusing about saying single pole 240 or two pole 240?
diystephen is offline   Reply With Quote
Old 02-10-2013, 10:45 PM   #29
Close to retirement
is it 110 or 220
Well it depends if the item was made for the USA. I have a lot of shop equipment made in china that was built for use in the USA and it’s what it says it is. Somehow I have a hard time believing that a item built in China and sent to the US would be anything else.
Now if the OP was actually in China when purchasing it and then had it sent here, that would be another story. But I’m not buying it because it was ordered here and the seller knows it’s marked for USA. I buy electrical stuff on eBay from China all the time and never have I gotten anything that was not compatible with USA standards
Old 02-10-2013, 10:50 PM   #30
Close to retirement
is it 110 or 220
Well I know the difference, but thats not what a real electrician would say. I've been a licensed electrician for 35 years and I've never heard a electrician refer to it in those terms. Now maybe you do where your from, but not in CA.
Now one might say "single pole 240 relay" or "two pole 240 switch" but never referring to a circuit.
