Is It 110 Or 220 - Electrical - DIY Chatroom Home Improvement Forum
Old 02-10-2013, 11:55 AM   #1
is it 110 or 220
I have a machine i ordered from china the cord has 3 prongs and 10a 250v wrote on it.is it 110 or 220?
she777 is offline   Reply With Quote
Old 02-10-2013, 12:03 PM   #2
Master Electrician
Rewards Points: 3,776
Does the cord cap have a NEMA # ? It's probably 240 volts.
brric is online now   Reply With Quote
Old 02-10-2013, 12:06 PM   #3
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
In the USA we have single phase 240 volts over two hot conductors accompanied with a non current carrying ground. This may be what you ordered. The plug is 250 volt rated so it is not a 110 volt plug or it would say so
What is it?
Thing to be careful about is that it is for use in the USA as 250 volts in many places in the world comes over one current carrying conductor and a grounded leg or neutral .. plus a ground .. it is also a 3 prong plug.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 02-10-2013, 12:36 PM   #4
MarginallyQualified
Rewards Points: 2,464
post a photo of the plug and the "rating plate" on the machine
Old 02-10-2013, 01:02 PM   #5
Rewards Points: 258
there might also be a wireing diagram plate, if there is a pic of that would help as well.
redman88 is offline   Reply With Quote
Old 02-10-2013, 01:09 PM   #6
Rewards Points: 1,452
Even though most household equipment sold in China is 220 (240?) volt, you should not simply go by the rating of 250 volts stamped on the power plug (cord cap).
You must find out more about the machine. The voltage stamped on the name plate is good enough to rely on.
Old 02-10-2013, 03:28 PM   #7
Retired
Well here in the US you cannot plug rated plug into anything else other than the same rated receptacle. There are different Amperage plugs and the amperage rating has to also match. It could be 20Amp 2-wire or 3-wire with ground or 30 or 50 amp with 2-wire or 3-wire with ground which would be designated buy the NEMA rating
Do not worry about 220, 240, 230 or 250V because it all the same. Manufactures have to overrate the plug to accommodate different areas of the country and the incoming Voltage could be anything. The only cause for concern is when it says 208V because that is probably 3 phase.
I’m pretty sure its 220 and definitely not 110V
JohnnyB60 is offline   Reply With Quote
Old 02-10-2013, 07:14 PM   #8
Master Electrician
Iím pretty sure its 220 and definitely not 110V
I can easily insert a 15 amp 125 volt plug into a 20 amp 125 volt receptacle.
Old 02-10-2013, 07:29 PM   #9
Retired
Yes you can but you can not insert a 20 amp plug into a 15 amp receptacle. It is allowed to plug a 15amp in a 20 amp circuit as long as its the same voltage range.
Well you got there but that wasn't the question. We were talking about the difference between 110V and 220V. You will not be able to plug ANY 110V, 115V, or 120V INTO a 210V, 220V, or 240V
Last edited by JohnnyB60; 02-10-2013 at 07:32 PM. Reason: Had to put in the volts for the nit pickers
Old 02-10-2013, 07:40 PM   #10
Rewards Points: 1,002
Voltage is voltage whether it is between two hot poles or hot and ground
Anti-wingnut is offline   Reply With Quote
Old 02-10-2013, 07:49 PM   #11
Rewards Points: 506
But a 240 volt single pole circuit and a 240 volt double pole circuit are each intended for specific equipment/devices.
jlmran is offline   Reply With Quote
Old 02-10-2013, 08:00 PM   #12
Whats a single pole circuit?
240v hot to ground(ed) looks the same as our standard (US) hot to hot when viewed on an oscilliscope.
Items made specifically for North America will be built for a 240 hot to hot circuit, but other items built with a 240v hot to ground circuit (EU) can still be safely used.
One can also use a single phase of a 240v three-phase system.
Old 02-10-2013, 08:04 PM   #13
Retired
I don’t know what you are talking about by 240 volt double pole circuit. Double pole usually means opening both sides such as a contractor or rely. I think you're maybe referring to a 3 wire circuit where you have two lines with 240 volts between them and a neutral wire for 120V.
Last edited by JohnnyB60; 02-10-2013 at 08:13 PM. Reason: Sorry I was trtying to type to fast and got my thought mixed up
Old 02-10-2013, 08:06 PM   #14
All circuits except three-phase and short circuits require two poles.
Old 02-10-2013, 08:07 PM   #15
joed's Avatar
Rewards Points: 12,024
Yes but if plug a 240 hot to ground device into a 240 hot to hot device then you may have just applied 120 volts relative to ground onto the metal framing of the device.
