Old 09-10-2008, 05:10 PM   #1
UAW SKILLED TRADES
Stubbie's Avatar
11 ground termination question
I have 7... 14 awg cables entering a 4 gang plastic box with 4 3-way switches. 3 cables coming from the other 3 ways and 3 cables leaving for the loads (one is a 14/3 using the 4th switch) and also the incoming power cable. Thats seven cable equipment grounds and 4 device pigtails totaling 11 bare grounds. I'm curious the different ways you guys would handle the termination of the grounds as to wirenuts, jumpers etc....
Old 09-10-2008, 05:16 PM   #2
Moderator
Termite's Avatar
Not sure how many you can get in a Buchanan by listing, but that might be more fun than a wire nut.
Old 09-10-2008, 06:46 PM   #3
" Euro " electrician
frenchelectrican's Avatar
Stubbie did you say 11 ??
Okie did you try big bleu wirenut that should work.,, otherwise split in two sets about half each and run a jumper wire between the two.
Normally i rather go with latter route unless this was a junction box point then go for it.
Merci,Marc
Old 09-10-2008, 06:53 PM   #4
I think I could get 11 #14 grounds under a blue nut. Bare grounds are pretty easy to lay next to each other. If they didn't want to squeeze in there, I'd probably twist them together tightly for a few inches to ensure a quality connection, then put the nut on.
If That didn't work, I'd split them up 5-6 and put a jumper between two nuts.
220/221 is offline   Reply With Quote
Old 09-10-2008, 06:57 PM   #5
Electrician
Simple, I would leave 4 of the grounds longer than the rest and just use a crimp, heck, I might even leave just one of the grounds really long and use a green wire nut.
chris75 is offline   Reply With Quote
Old 09-10-2008, 07:00 PM   #6
I always forget about crimps
Old 09-10-2008, 07:13 PM   #7
IIRC the crimps useally can take 4-6 depending if it is 12 or 14's
Merci,Marc
Old 09-10-2008, 07:22 PM   #8
What I would worry about is that with 11 conductors, some are bound to be caught "in the middle", meaning they would just be squished between the outer conductors instead of being twisted with them or being bonded by the metal of the wire nut. I would think they can "fall out" of their middle spot as the bundle gets pushed around in the box.
I would feed good with this, using 3 wire nuts or crimps, each with 4 grounds and the switches jumpered together:
BTW, this is one reason I don't agree with the box fill requirements counting all grounds as one allowance. They certainly take up space. In your case, the box fill would be 24 allowances, or 48 cu in.
Willis
williswires is offline   Reply With Quote
Old 09-10-2008, 07:29 PM   #9
Wills.,
Just one question related to your drawing about ground wire on the swiches did you just make a pigtail for each one or just loop format ?
Merci,Marc
Old 09-10-2008, 08:14 PM   #10
I was thinking a loop...
Willis
Old 09-10-2008, 08:30 PM   #11
Licensed Pro
8 hole Wago: 7 holes for the cables, 1 hole for a long piece looped around each switch. Folds in the box nicely.
Old 09-10-2008, 09:47 PM   #12
Electrical Contractor
kbsparky's Avatar
You could mount a ground bar kit in the back of that box.
Get one with 15 spaces in it ... Square D PK-15GTA. 11 for the wires, and 4 spares.
Old 09-10-2008, 10:28 PM   #13
Electrician
If the wire nut is listed for 11 conductors, then there will be no problem.
Old 09-10-2008, 10:52 PM   #14
UAW SKILLED TRADES
Stubbie's Avatar
Ok guys thanks I was on a job and had this situation so I played with it some and was just wanting to see how all of you would terminate the grounds. Usually I would just use wirenuts and a jumper as 220/221 mentioned, I never liked 11 in one wire nut. I mentioned the pigtails to each switch just to make sure I covered the likely maximum # of grounds. I found two ways that I liked the best. Twisted all seven neatly and left one long enough to catch all the switches using a greenie as Chris mentioned. The other was the one Househelper mentioned an 8 hole wago. I liked the wago the best.
EDIT: Doesn't make any difference but the 4th switch was not a 3 way but a single pole for the fan motor on a ceiling fan.
Old 09-10-2008, 10:54 PM   #15
Electrician
Personally, if the box was a 4 gang I would have used a metal box.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Ground question. mystery guest Electrical 5 07-24-2008 01:47 PM
Quick question: No ground bar in panel? dawho1 Electrical 3 04-06-2008 11:17 AM
Ground Clamps Question integlikewhoa Electrical 40 02-28-2008 10:13 PM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
