Old 11-14-2010, 02:47 PM   #1
100Amp Sub-panel wire gauge
I'm adding a 100 Amp main lug panel right next to my other panel (200 Amp service). Single family dwelling and my county uses NEC 2008 code. Just wondering the easiest wire to use to feed the panel (in an unfinished basement). Do you recommend sheathed SE/SER copper or THHN in conduit? Can I use #1 or #2 NM or does it have to be SE/SER? I'm just wondering what gauge and type of wire to use (don't want to take any chances with the inspector so I'd rather be conservative).
kentwb is offline   Reply With Quote
Old 11-14-2010, 06:18 PM   #2
Electrical Contractor
kbsparky's Avatar
A small conduit nipple, with some #3 type THHN copper wire should do the trick. You'll need at least a 1" nipple (I'd use a 1¼" offset nipple for this).
-KB
Old 11-15-2010, 02:16 PM   #3
Thanks! If it looks easier to do a sheathed cable and cable clamp what type and gauge would you use?
What's the minimum gauge wire required to run 9volts 50 feet? Fox Electrical 31 08-02-2010 02:49 PM
mixed gauge wire on 15 amp circuit GretaDIY Electrical 4 07-03-2010 04:20 PM
Multiple Panel Question theatretch85 Electrical 5 12-12-2009 06:26 AM
100 -> 200 amp panel upgrade questions philipjcaputo Electrical 1 10-30-2009 04:35 AM
Passing wire to another panel theatretch85 Electrical 5 09-21-2009 12:09 AM
