100AMP To 200AMP - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-01-2011, 07:47 AM   #16
Master Electrician
Rewards Points: 3,746
Where in Indiana?
brric is online now   Reply With Quote
Old 02-01-2011, 09:42 AM   #17
Licensed electrician
Rewards Points: 1,240
Originally Posted by Speedy Petey View Post
With all the STUPID codes and rules in Ill they let you pull meters? That amazes me.
Sure is a whole lot safer than NM-B, not.
Old 02-01-2011, 10:03 AM   #18
Electrical Supplier
Rewards Points: 150
Dayton Power and Light in Ohio allows you to pull meters also. But you can have them come out and cut the transformer feed for a nominal fee.
"Do it right the first time and avoid duplication of effort"
Your AHJ/Inspectors ALWAYS have the final say on ANY electrical code issue.
If in doubt, contact a licensed, experienced, reputable electrician to perform the work.
LyonsElecSupply is offline   Reply With Quote
Old 02-01-2011, 09:19 PM   #19
Talked with both the power company and the inspectors office.. They will cut the power for free and i can do the work my self as long as they come out and inspect it before the re hook ... Going total electric thats why i wanted 200 AMP....
I really thought what i needed to do was replace the old wire and meter pan.. Replace the old wire with newer .. biger sizes.. Replace the meter pan with a 200AMP
childers2 is offline   Reply With Quote
100AMP Main board off a 100AMP Main Fuse cmarcus3031 Electrical 18 03-19-2014 11:17 PM
cost to change 100amp service to 200amp DIYGST Electrical 2 01-02-2010 10:06 AM
converting from 100amp to 200amp shaheed456 Electrical 3 11-04-2009 07:50 AM
100amp to 200amp box JNICO Electrical 6 06-08-2008 04:10 PM
upgrading 100amp breaker system to 200amp gloomis29 Electrical 10 01-31-2008 04:15 PM
