100A Service - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-26-2011, 03:32 PM   #16
Missouri Bound's Avatar
The reason I asked about your "where I live" statement is that in no way should you work on a property which you rent, that's up to the landlord to do that work, not the renter. Ownership is a different matter.
Old 07-26-2011, 03:42 PM   #17
I=E/R
a7ecorsair's Avatar
Originally Posted by loyal View Post
The wires in the boxes are all cut flush with the wall with the ends stripped and stabbed into the back of the receptacle. The stab connector can't be released because you can't get behind the receptacle because the leads are two short. So the leads have to be cut
even shorter to remove the recept. And of course they are all the small metal boxes. No grounding pigtail and no ground wire to the receptacle.
Perhaps you can understand that just trying to do simple maintenance on this house becomes a reconstruction project.
If you have to change a receptacle, have you tried crushing the old one with a Channel Lock pliers?
a7ecorsair is offline   Reply With Quote
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Service mast options bsperr Electrical 6 12-09-2009 09:48 AM
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 09:14 PM
updating 100A Service gnharrold Electrical 9 12-28-2008 12:48 AM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 11:31 AM
