100A Pannel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2009, 09:40 AM   #1
100A pannel question
I have a newer stab lok panel but most of the circuit breakers seem to be old.
For example the 40A double poll breaker for the stove takes 4 spots.
I'm thinking of getting modern low profile 40A breaker that will only take 2 spots. That free's up 2 spots for a new circuit(s).
I also understand that the more circuits I add, the more of a rats nest the panel can become.
If I replace all the breakers with low profile, can I over do it? or maybe my question should be at what point to you need a 200A panel?
unixb0y is offline   Reply With Quote
Old 03-09-2009, 09:50 AM   #2
Remodeling Contractor
A 2P40 breaker needs two spaces not four. You must be looking at some 1/2" size mini breakers already in your panel. You need to see what the maximum number of circuits are allowed in your panel. This number will be listed on a label on the cover. Something like 20/26 would mean 20 full size breakers or you can add 6 more circuits by adding 6 mini breakers. Sounds like you are already overloaded and need to upgrade the entire service to 200Amps.
Old 03-09-2009, 09:59 AM   #3
Bob, thanks for the info. I'll have to check the panel tonight... Maybe i'll post a picture.
What I suspect happened is that the panel for replaced but they kept the old breakers. There seems to be 3 vintages of breakers, 1 real old, maybe one that came with the pannel and then the new low profile stab lok breakers.
Old 03-09-2009, 10:00 AM   #4
Not necessarily. I believe there are "thin" and "thick" versions of some of the 2 pole breakers. "Thin" took 2 spots and the "thick" took 4 spots.
jerryh3 is offline   Reply With Quote
Old 03-09-2009, 10:07 AM   #5
What brand would that be. The bus uses 1" per circuit. When using 1/2" or mini breakers you put two breakers on the one bus slot. Or use a tandem breaker and two circuits are available on the one 1" space. Any panel used 2" per space would be very long.
Old 03-09-2009, 10:21 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,992
Not at all Bob.
FPE uses 1/2" and 1" breakers, which is what the OP has. Neither is standard over the other. Some panels DO limit where 1/2" breakers can be placed though.
C-H CH series and Sq D QO series are both 3/4" per space.
Sure, 1" is a very common breaker size, but not nearly all there is.
Unix, the label will tell you where you can put a 1/2" breaker. It may be hard to figure out, but the information is there.
Old 03-09-2009, 10:22 AM   #7
UAW SKILLED TRADES
Stubbie's Avatar
Rewards Points: 2,652
I suspect what he has is a quad breaker, very common.
" One nice thing about the NEC articles ... you have lots of choices"
Stubbie
Old 03-09-2009, 10:34 AM   #8
UAW SKILLED TRADES
Stubbie's Avatar
After rereading I believe Speedy is correct, the op is just saying that his double pole 40 takes the same space as 4.... 1/2" stab-loks.
Stubbie
Old 03-09-2009, 08:23 PM   #9
Yea, that's what I was trying to say.
Here is a picture of the panel
  • top left 40 amp oven breaker
  • bottom left hand side is the dryer
  • middle right the the air conditioner
  • bottom right(green) hot water tank
Old 03-09-2009, 08:38 PM   #10
So you're in Canada.
Old 03-09-2009, 10:18 PM   #11
The panel number is be-116-32
Also, stab lok's only seem to be available in 1/2" sizes.
So i'm confused over how many 1" double poles and how many 1/2" sizes I can have.
Old 03-10-2009, 02:43 PM   #12
Or more to my question.
  • swap out the 2" oven double pole with a new 1" double pole and gain 1"
  • swap out the 2" dryer double pole with a new 1" double pole and gain 1"
  • swap out the 2" double pole fireplace plug for a 1/2" single pole 15A and gain 1.5". I don't need 30 amps anymore since we now have a 1500w fireplace.
I gain up to 3.5" or seven 1/2" spots. In the future, am I over loading things if I add another 7 stab lok's.
Old 03-11-2009, 10:46 AM   #13
One last bump
Old 03-11-2009, 10:55 AM   #14
Rewards Points: 2,350
Can you snap a pic of the bus behind one of the 1" spaces? I ask because this appears to be a Federal Pioneer panel, and most of us here in the States aren't very familiar with them. The pic would help answer your question.
Old 03-11-2009, 11:11 AM   #15
UAW SKILLED TRADES
Stubbie's Avatar
That's pretty close but remember when you use the 1/2" double poles the 1" you gain will be a 1/2" above and a 1/2" below the new double pole breaker as it needs to catch two buss stabs in order to have opposite legs for 220 volts. Look at the 1/2" double pole in the bottom right...notice it has a 1/2" single pole directly below it. So what I'm saying is that one pole of the double pole (green) and that 1/2" single pole share the same bus tab same thing with the 1/2" double pole above the new (green double pole). But you do create two 1/2" single pole spaces...one above and one below the new 1/2 size double.
Stubbie
Understanding 120V branch loads in 100A 240V system WaldenL Electrical 17 02-17-2009 09:15 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
New service Question Onytay Electrical 1 10-24-2007 05:47 AM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
Wiring 100A subpanel nebulous Electrical 9 08-29-2007 02:41 PM
