100 Amps Breaker Wire Size? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2012, 03:12 PM   #1
100 Amps Breaker wire size?
Hi, I have a bad neutral from circuit breaker to my meter(115 feet) I need to install the new wires. I have 100 Amps breaker, I want to know which gauge size of aluminum wire should I install?
daythunder is offline   Reply With Quote
Old 06-07-2012, 04:06 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
The meter contains the 100 amp breaker correct?
Old 06-07-2012, 04:13 PM   #3
Code05's Avatar
Rewards Points: 1,104
And does the feeder carry the whole house and auxiallary loads on a resi 120/240V install?
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
zappa (06-08-2012)
Old 06-07-2012, 04:19 PM   #4
E2 Electrician
That was my next question.
Old 06-07-2012, 04:29 PM   #5
Code05's Avatar
I know.
Old 06-07-2012, 05:31 PM   #6
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
What size wire is currently installed?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 06-07-2012, 06:50 PM   #7
Main panel has 100 amps main breaker. Currently meter is locked so i cant see the wire size.
What size wire and breaker needed? stlouistruckn1 HVAC 4 02-06-2012 09:35 PM
Breakers, wire size and new heat pump ACR_SCOUT Electrical 21 01-29-2012 02:25 PM
240v conduit with different gauge wires... Biospot Electrical 7 12-14-2010 07:07 PM
20A Breaker, 14 gauge wire? joside Electrical 12 08-25-2010 09:41 AM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
