100 Amp. Subpanel - Electrical - DIY Chatroom Home Improvement Forum
Old 01-25-2012, 11:10 AM   #1
Retired NYPD
100 amp. Subpanel
I have talked on this subject before. I have new info. The sub panel is a 100 amp. Panel, but I had to put a 75 amp. Cb because the wire was aluminum. My main panel is 150 amp. With 2 slots open. In the sub panel is 10-15 amp. CB's and 4-20 amp. Cb's. I want to put in an electric stove,so I need either a 40 amp. Or 50 amp.cb. The sub panel has 24 slots. It is a homeline,Homc24 uc. Is this possible to do?
FrankLa is offline   Reply With Quote
Old 01-25-2012, 11:20 AM   #2
Julius793's Avatar
Why would you put it on a 75a breaker if it can handle 100a?
What size wire did you run?
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 01-25-2012, 11:25 AM   #3
Retired NYPD
I was told by the electrical inspector that the aluminum wire is only for a 75 amp cb. It is too late to change it now. Already have used this panel, and the basement is finished and no access to wires.
Old 01-25-2012, 11:27 AM   #4
Julius793's Avatar
Oh ok I just looked at your other post. Now how far away is the main panel? I would put the stove there and not in the sub. In addition it may be a good time to start thinking about a service upgrade if theres an electric water tank, electric heaters Ect....
Old 01-25-2012, 11:43 AM   #5
Retired NYPD
There is no electric wh or heaters. Service upgrade is out, the house is only 5 yrs. old. Can I put in a 40 or 50 amp. Cb. In the sub panel? Main panel is a whole lot of wire and a lot of work. Not in the equation.
Old 01-25-2012, 11:45 AM   #6
Julius793's Avatar
Yes code wise not a problem.
The Following User Says Thank You to Julius793 For This Useful Post:
FrankLa (01-25-2012)
Several Questions...leading to Garage Subpanel willstutely Electrical 5 01-03-2012 01:38 PM
Subpanel Right Below Main dcapone Electrical 6 01-02-2012 04:46 PM
Wiring Subpanel off Subpanel brgmgb Electrical 2 08-29-2011 04:18 PM
Problems with Square D Subpanel bltglt507 Electrical 16 12-04-2009 08:44 PM
A few slightly different questions on subpanel wiring. Chris Dopp Electrical 8 06-26-2009 09:45 PM
