100 Amp Sub Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 02-03-2010, 12:53 AM   #1
100 amp sub panel question
I would like to add a 100 amp sub-panel in my basement due to lack of space in the 125 amp main and for future expansion, but the neutral and ground bus bars in my main panel and the ground bar in my sub will not accommodate the 2-2-2-4 aluminum wires. any ideas?
Thanx, Mac
macddmac is offline   Reply With Quote
Old 02-03-2010, 06:06 AM   #2
You do not get power for a subpanel off the buss, you get it from a breaker, if I correctly understand what you are suggesting. You can't run a length of unprotected(no disconnect device) cable/wires.
Old 02-03-2010, 06:43 AM   #3
47_47's Avatar
Rewards Points: 58
I would consider upgrading or changing the main panel. To connect larger wires to the existing neutral and ground busses use a neutral lug. The hot wires land on an appropriate sized breaker in the main panel.
47_47 is online now   Reply With Quote
Old 02-03-2010, 10:35 AM   #4
I looked the neutral lug and it looks like what i need-thanks, Mac
Old 02-03-2010, 11:11 AM   #5
47_47's Avatar
Rewards Points: 58
You are welcome. Not an electrician, but there are bus amperage ratings of panels which you need to look into.
My take, even if allowed, feeding a 100 amp sub from a 125 main, you'll be tripping the main. Do a load calculation and determine what size service you need or will need in the future and start there.
Panel History (old Breaker Panel Question) jamiedolan Electrical 3 01-17-2009 03:27 PM
Service Panel Question??? sv123 Electrical 4 10-06-2008 06:26 PM
Melted Service Entrance Wire in Panel theatretch85 Electrical 13 08-22-2008 10:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
3 phase panel question curse21 Electrical 2 08-18-2004 10:17 PM
