100 Amp Sub Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-09-2010, 08:23 AM   #1
100 amp sub panel
We are looking at running a feed from the main 200A panel in the (attached) garage to a 100A sub-panel in the basement. The run is about 125 feet and the cable will be run in the attic where the head height is less than 3 feet. My question is: What is the best cable choice for this? #2 or #3 sheathed 3 wire plus ground, run like a range cable to the 100 panel? This size sheathed 3 wire wire does not seem to be readily available here. Can we use 2 #3's (red&blk) + 1 #6 neutral (wht) + 1 #6 ground (green or bare) run in 1 inch pvc conduit? The second choice makes use of the changed (reduced) neutral size requirement in the 20th edition of the Canadian code. Other options? We're in Thunder Bay, Ontario, Canada.
fpianka is offline   Reply With Quote
Old 11-09-2010, 08:34 AM   #2
Just call me Andrew
Rewards Points: 1,020
I think individual THHN conductors in conduit is the way I'd do it. Assuming no voltage drop (how long is the run?) you would need:
3 x #3 (red, black, white)
1 x #8 Green or Bare for ground
The minimum size Sch 40 PVC conduit for these conductors is 1" - oversizing wouldn't be a bad thing.
Edit: I just noticed that you're in Canada. My post is based solely on my knowledge on US Code.
Andrew
secutanudu is offline   Reply With Quote
Old 11-13-2010, 03:39 PM   #3
I found out, before we bought any wire, that the largest sub-panel you can run off a 200A main panel is 60A. At least in Ontario.
Old 11-13-2010, 04:28 PM   #4
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
that is not the same in the US. Here I can run a 200 amp panel from a 200 amp panel.
there are a couple Canadian electricians that post here. You might want to stick around and see if they post to this thread. I know Canada has some odd restrictions compared to the US rules but that one seems exceptionally odd to the point I can't see it making any sense.
but this is also another reason people should post their location. It makes a lot of difference with certain situations.
Multiple Panel Question theatretch85 Electrical 7 09-29-2016 07:15 PM
new sub panel BlueBSH Electrical 11 01-22-2012 08:28 AM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 10:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 03:03 PM
