100 Amp Sub Panel 70 Feet From Main Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 03-23-2013, 02:05 AM   #1
100 amp sub panel 70 feet from main panel
I am throwing out a question. We are installing a 100 amp sub panel in a garage. It is approximately 70 feet, as the cable runs, from the Main Panel. I planned on using #2 SER but am confused as to derating. I have heard 2 ser was OK. Another associate says 2 ser is only good for about 80 amps by derating. The main service panel is GE and I need to find the derated breaker which is not available at a box store of course. Any insight is appreciated.
pwcontracting is offline   Reply With Quote
Old 03-23-2013, 07:42 AM   #2
Rewards Points: 13,712
Deleted
Old 03-23-2013, 07:46 AM   #3
An old Tradesmen
Rewards Points: 7,298
Moved to Electrical forum.
Old 03-23-2013, 08:06 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
edited my post due to OP's username
Old 03-23-2013, 08:08 AM   #5
Also please go back and add your location to your profile,
Go to Quick links to edit.
DO not just mention it in your post.
Old 03-23-2013, 08:25 AM   #6
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
So you're an electrical contractor and you're coming here to find out how to do a proper installation?
And what did you mean by "associate"? An electrician or an associate at a big box store?
JulieMor is offline   Reply With Quote
Back up generator for main panel in power outage. Greenie Electrical 44 07-29-2015 10:57 PM
Wiring main panel without dying Maxian Electrical 8 11-18-2012 10:11 AM
200A upgrade and move, backfeeding permitted? WillK Electrical 3 05-30-2011 08:00 PM
wiring sub panel right next to main panel bill423 Electrical 4 05-14-2011 08:17 PM
Replace main panel? And lots of other ?s Bcoleman6 Electrical 13 01-22-2008 09:40 AM
