Old 03-22-2009, 09:11 AM   #1
100 amp sub panel
Just had the main service panel in the basement upgraded from 100 to 200 amp. The old panel was totally inadequate and outdated. The new panel, Square D QO model is great.
Want to upgrade the old service panel in the garage to 100 amp sub panel. The panel in the garage is a fused type. Soooo, what size wire do I need to run from the 200 amp panel to the 100 amp? I have a small mig welder, 220, and lights and outlets garage door openers, etc....
Donald A is offline   Reply With Quote
Old 03-22-2009, 10:14 AM   #2
Remodeling Contractor
100 amp sub panel
# 2 wire in conduit, but easier to use something like 2/0 SEU cable or get some #2MC cable from an electrical supply house
Old 03-22-2009, 12:08 PM   #3
J. V.'s Avatar
100 amp sub panel
This is a hot topic on this forum. There is more information on sub panels here than anywhere else I know of. Just use the search function on the top of this page and you could read about sub install for weeks.
If you still have questions, please let us know. We are glad to help.
Old 03-22-2009, 08:24 PM   #4
100 amp sub panel
Thanks for the information. Looks like I will need to do some research as I don't have a clue what you just said.
Old 03-22-2009, 08:26 PM   #5
100 amp sub panel
yes read up on all different ideas. What I am saying is that different wires are used for different installation requirements. You need to post what the conditions are before we can narrow down an answer
Old 03-22-2009, 08:26 PM   #6
100 amp sub panel
I will use the search function as suggested, thank you.
Old 03-24-2009, 07:20 AM   #7
Gettin' Electrified
100 amp sub panel
This is a great topic! I was wondering the same thing
Chris-D is offline   Reply With Quote
Old 03-24-2009, 03:01 PM   #8
Xtreme DIY'r
100 amp sub panel
I'd get rid of the fused panel
A breaker sub panel isn't that expensive
Old 03-24-2009, 04:15 PM   #9
100 amp sub panel
Installing a new 100 amp panel is the plan. Just need to get the panel, fuses and wire.
Old 03-25-2009, 01:29 AM   #10
DIY Junkie!!
100 amp sub panel
I recently upgraded the electrical service to an old family home from 100 amp overhead to 200 amp underground. In addition, I had a direct run of wire laid from the meter box to the garage, and installed a 100 amp service panel there. It's relatively straight-forward, not exactly a drop in but I had more difficulty mounting the box than wiring it when it was finished. The Home Depot 100 amp service panel has spaces for 30 circuits (I think that's right, but the location is about 800 miles away right now so I can't check, sorry). I felt that was more than adequate for the limited amount of lighting and electrical usage the garage would get, not much right now and when I want to expand, like add an electric kiln for ceramics projects, there's potential there......all in all an easy project.
The new install on the garage was most certainly easier than the replacement of the old 100 amp service panel in the house with a 200 amp/40 circuit model.....I almost had to splice wires in, some of the existing wiring was pretty short, but in the end I managed.
There was no requirement in this area for a grounding rod. Got lucky there !
Good luck and let us know how it goes, please!
Dugly
YerDugliness is offline   Reply With Quote
Old House Rewire finnimus Electrical 15 05-13-2011 11:39 PM
Adding a second Electric sub panel TW Lucas Electrical 9 10-05-2008 03:37 AM
Replacement Meter Panel leonard_voet Electrical 19 04-09-2008 11:27 AM
Installing new (service?) breaker panel and generator panel Nhrafan Electrical 6 04-01-2008 04:03 PM
turn main panel into a sub panel? tikicarver Electrical 2 01-24-2008 08:37 AM
