100 Amp Service Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 05:52 AM   #1
100 amp service panel
question.. from a newbie... so if i install a 100 amp service panel, does that mean i can only have 5 20 amp breakers in that box?...
ll2none is offline   Reply With Quote
Old 11-15-2011, 06:08 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
No, not even close.
You can have ANY breakers you want in the panel. It's the calculated, and actual load, that will be on the panel that matters.
Speedy Petey is online now   Reply With Quote
The Following User Says Thank You to Speedy Petey For This Useful Post:
ll2none (11-15-2011)
Old 11-15-2011, 06:20 AM   #3
Licensed electrician
Rewards Points: 1,494
It would be common for the handle breaker ratings to add up to 2-300 amps in a 100 amp panel. Handle ratings as Speedy said, do not determine the load.
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
200 amp panel w/100 amp service PirateKatz Electrical 8 12-26-2009 03:42 PM
Replacing 2 Sub Panels with 1 Larger Panel GuitarJack Electrical 7 08-25-2009 08:43 PM
Upgrade Service Panel - Do I need a new meter? El Kati Electrical 6 08-11-2008 07:35 PM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
