100 Amp Serivce? - Electrical - DIY Chatroom Home Improvement Forum
Old 07-06-2011, 06:14 PM   #1
100 amp serivce?
We just purchased a 1930 home. How can we tell if we have 60, 100 or 200 amp electric service. there are both fuses and breakers and the main box outside is breakers. I was told that since there is a heat pump that it can ONLY be 200 amps. Help!
sugardog is offline   Reply With Quote
Old 07-06-2011, 06:47 PM   #2
Rewards Points: 6,652
If original to the structure with Fuses, most likely 60 amp. If breakers, it will state on the handle of the breaker. Go look on the outside disconnect, and see what it states. You are welcome to post pictures of both panels, including the meter box & rainhead if you wish.
Old 07-06-2011, 08:49 PM   #3
Electrician
SD515's Avatar
Rewards Points: 504
Find the first fuse or breaker after the meter, (most likely) that’s going to be the main service disconnect, and that’s going to be your service size.
Kyle
Upgrading ---> 200 amp serivce jelly Electrical 22 10-27-2008 12:12 PM
