100 Amp Breaker - Electrical - DIY Chatroom Home Improvement Forum
Old 04-13-2013, 01:52 PM   #1
100 amp breaker
can i put a 100 amp breaker in a 60 amp box
larry60 is offline   Reply With Quote
Old 04-13-2013, 01:57 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'll take "How not to get a useful answer on a DIY forum for $800, Alex"
The Following 2 Users Say Thank You to k_buz For This Useful Post:
gregzoll (04-13-2013), mpoulton (04-14-2013)
Old 04-13-2013, 02:01 PM   #3
Master Electrician
Rewards Points: 3,874
Yes. A 100 amp breaker will fit in a 60amp carton( box).
brric is online now   Reply With Quote
Old 04-13-2013, 02:15 PM   #4
so the wire coming from the meter into the house is the right size or do i need to change that too
Old 04-13-2013, 02:25 PM   #5
Banned Electrician
HARRY304E's Avatar
Rewards Points: 204
If the wire coming from the meter is only good for 60 amps then you cannot use the 100 amp breaker.
You need to find out what size that wire is so you know what to do.
"Government is not the solution to our problem; Government is the problem."
HARRY304E is offline   Reply With Quote
Old 04-13-2013, 02:30 PM   #6
ok thanks i will find out
Old 04-13-2013, 03:12 PM   #7
And most likely code won't let you change the wire without being licensed. Your electric provider won't re hook it without a sticker on the box from code enforcement. Best thing to do is call an electrician or your local code office and ask.
jsbuilders is offline   Reply With Quote
Old 04-13-2013, 03:14 PM   #8
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I wouldn't say most likely, anyone in CT can do their own residential service, of course, they cannot do a cut and re-connect.
Old 04-13-2013, 03:23 PM   #9
Oso954's Avatar
Rewards Points: 1,126
And they will never sign it off, with a 60 amp panel. It must be changed out.
Oso954 is online now   Reply With Quote
Old 04-13-2013, 03:31 PM   #10
The better question is why anyone put a 60 amp panels in a house. Or even a 100
Old 04-13-2013, 03:48 PM   #11
E2 Electrician
Because you don't need more than 100 amps...
The Following User Says Thank You to stickboy1375 For This Useful Post:
micromind (04-13-2013)
Old 04-13-2013, 03:56 PM   #12
I'm actually laughing right now. And you call yourself an electrician. I honestly hope you're joking. I would never ever consider putting anything smaller then a 150 amp. And you're more likely to see 200 amp panels in my houses. Then you will never have the op's problem.
Old 04-13-2013, 04:01 PM   #13
k_buz's Avatar
The smallest service allowed by the NEC is 100A. Years ago, 60A services were standard. As the years have gone by, we have become more and more energy dependent. What Stickboy is saying that it is VERY rare for a dwelling to ever draw more than 100A. If it did, the vast majority of homeowners wouldn't be able to afford the bill.
The Following 4 Users Say Thank You to k_buz For This Useful Post:
frenchelectrican (04-13-2013), jbfan (04-13-2013), micromind (04-13-2013), mpoulton (04-14-2013)
Old 04-13-2013, 04:51 PM   #14
Ever do a load calc?
Ever bid work?
Ever notice a utility xfrmr is commonly 25 kva for a 200 amp service?
ren79eg is offline   Reply With Quote
The Following User Says Thank You to ren79eg For This Useful Post:
Old 04-13-2013, 08:03 PM   #15
" Euro " electrician
frenchelectrican's Avatar
150 amp panels are not super common items in quite few area so I will not bother with that.
Try to come over here in European side and see some of the electric service yourself and you should say thank god the North American panels have pretty good service size.
The small house over here in France the common service size can go from single phase 30 amp service on the flats ( apartments ) to 80 amp monophase for resdentail homes but once you get over 80 amp service size you will have no choice but go with triphase main service ( we can get smaller service on triphase due it can be cheaper plus we can get more KW load on triphase vs monophase is )
If ya think I am joking ., just enjoy the ride you will find out soon. ( sorry if I am harsh but I am not )
Merci,
Marc
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 07:27 PM
Well pump trips breaker at start, but then starts when breaker reset J. David Electrical 34 02-25-2012 11:23 AM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
