Old 12-01-2012, 12:24 PM   #1
Post
100 AMP Braker Box or200 AMP Braker Box
I have just rewired my home with 12-2 with ground and would like to know which to go with the braker box, right now I have a small 100 AMP box and need more space. So should I stay with the 100 AMP or go with the 200 AMP box?
I have a GAS Drier, Gas Stove & Oven, and a Gas Water Heater.
Everything else is Eleectal.
Yes I have AC.
nhoj is offline   Reply With Quote
Old 12-01-2012, 12:26 PM   #2
Licensed Electrician
k_buz's Avatar
You cannot simply replace the panel with a larger panel.
Location...Location...Location
Old 12-01-2012, 12:30 PM   #3
Yes I understand that. But you have to decide which way to go on this before you start digging and putting in new cable.
Old 12-01-2012, 12:35 PM   #4
k_buz's Avatar
You wouldn't need to dig and replace cable if you "stay with 100A".
To your OQ, I would stay with 100A if all you have done is rewired the home and haven't added any significant loads. If you have added loads, or plan to, I would upgrade to 200A.
Old 12-01-2012, 01:10 PM   #5
What do you mean in up gradeing: What type of equement or household applances would you say that would make you go to 200 AMPS.?
Old 12-01-2012, 01:12 PM   #6
Would you say that I already have 220 going to the house and they cut it down before going into the house?
Old 12-01-2012, 01:23 PM   #7
k_buz's Avatar
With this post, it is quite obvious that you should not be working on the electrical service. You need to call a licensed electrician.
The Following User Says Thank You to k_buz For This Useful Post:
tahomerepairs (12-02-2012)
Old 12-01-2012, 01:23 PM   #8
Licensed electrician
240 is the voltage in the house.
To determine your service size you do a demand load calculation.
Old 12-01-2012, 01:33 PM   #9
I am not doing the work but I feel that I have every right to know what needs to be done.
An yes we are going to do a demand calculation.
As we were talking they feel with all the Gas Appearances that I have I am not pulling over 100 Amps. They feel that I am pulling about 70% or less.
Old 12-01-2012, 01:39 PM   #10
k_buz's Avatar
My opinion is that you are fine with a 100 A service as I do not believe you actually draw 70A. The calc may come out to that number, but it is rare to draw that much with no electric appliances except AC.
Old 12-01-2012, 02:26 PM   #11
The only things that I have electric id the Amplifier, Refrigerator, Microwave, dishwasher, TV, DVD Player, CD Player, and Computer. That is it.
Old 12-01-2012, 03:07 PM   #12
JOATMON
ddawg16's Avatar
I'm wondering what a "Braker" is.......
As for panel size.....unless you have a garage with some heavy duty power tools...a 100A 'breaker' panel (load center) is fine.
If your hurting for more circuit breakers, see if your panel can use tandem breakers. The panel has to be rated for it.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 12-02-2012, 06:56 AM   #13
Post
I was told if I went to a 200 Amp. box from a 100 Amp box you would save energy and lower your Electric Bill. I just don't understand how this can happen.
I know if you go from 14-2 with ground to 12-2 with ground you electric wire will run cooler.
Can someone please explain how you would be able to lower your electric bill by changeing from 100 Amp. box to a 200 Amp box?
I was told that the 200 Amp box would not make make things work harder and would make your applances last longer. Can you explain this also.
Old 12-02-2012, 07:44 AM   #14
Post
K_buz Is it true that if you change from 100 Amp to 200 Amp you will save energy and lower your electric bill?
I was told this by selveal people and I just don't understand how that could be.
They told me that your applances would not work as hard and it would save the wear and trere on them and that would lower your electric bill allown.
I do know by going from 14-2 with ground to 12-2 with ground your wires will stay cooler and not over work themselfs.
Old 12-02-2012, 08:17 AM   #15
k_buz's Avatar
Neither of these two will have any affect on your electric bill.
Central Ac Unit Keep Causing My Electric Braker To Kick Off pamelah1105 HVAC 1 06-18-2012 12:58 PM
single wall convection oven wire and braker cgipson Appliances 0 02-22-2011 10:32 PM
New 20 amp braker to panel. Can I use 14 gauge from dimmer to light fixture? nlako Electrical 6 02-11-2011 09:38 PM
What size braker should I use? chopshop Electrical 11 08-13-2010 10:06 PM
