-   -   100 AMP Braker Box or200 AMP Braker Box (http://www.diychatroom.com/f18/100-amp-braker-box-or200-amp-braker-box-165267/)
nhoj 12-01-2012 12:24 PM
I have just rewired my home with 12-2 with ground and would like to know which to go with the braker box, right now I have a small 100 AMP box and need more space. So should I stay with the 100 AMP or go with the 200 AMP box?
I have a GAS Drier, Gas Stove & Oven, and a Gas Water Heater.
Everything else is Eleectal.
Yes I have AC.
k_buz 12-01-2012 12:26 PM
You cannot simply replace the panel with a larger panel.
nhoj 12-01-2012 12:30 PM
Yes I understand that. But you have to decide which way to go on this before you start digging and putting in new cable.
k_buz 12-01-2012 12:35 PM
You wouldn't need to dig and replace cable if you "stay with 100A".
To your OQ, I would stay with 100A if all you have done is rewired the home and haven't added any significant loads. If you have added loads, or plan to, I would upgrade to 200A.
nhoj 12-01-2012 01:10 PM
What do you mean in up gradeing: What type of equement or household applances would you say that would make you go to 200 AMPS.?
nhoj 12-01-2012 01:12 PM
Would you say that I already have 220 going to the house and they cut it down before going into the house?
k_buz 12-01-2012 01:23 PM
With this post, it is quite obvious that you should not be working on the electrical service. You need to call a licensed electrician.
Jim Port 12-01-2012 01:23 PM
240 is the voltage in the house.
To determine your service size you do a demand load calculation.
nhoj 12-01-2012 01:33 PM
I am not doing the work but I feel that I have every right to know what needs to be done.
An yes we are going to do a demand calculation.
As we were talking they feel with all the Gas Appearances that I have I am not pulling over 100 Amps. They feel that I am pulling about 70% or less.
k_buz 12-01-2012 01:39 PM
My opinion is that you are fine with a 100 A service as I do not believe you actually draw 70A. The calc may come out to that number, but it is rare to draw that much with no electric appliances except AC.
nhoj 12-01-2012 02:26 PM
The only things that I have electric id the Amplifier, Refrigerator, Microwave, dishwasher, TV, DVD Player, CD Player, and Computer. That is it.
ddawg16 12-01-2012 03:07 PM
I'm wondering what a "Braker" is.......
As for panel size.....unless you have a garage with some heavy duty power tools...a 100A 'breaker' panel (load center) is fine.
If your hurting for more circuit breakers, see if your panel can use tandem breakers. The panel has to be rated for it.
nhoj 12-02-2012 06:56 AM
I was told if I went to a 200 Amp. box from a 100 Amp box you would save energy and lower your Electric Bill. I just don't understand how this can happen.
I know if you go from 14-2 with ground to 12-2 with ground you electric wire will run cooler.
Can someone please explain how you would be able to lower your electric bill by changeing from 100 Amp. box to a 200 Amp box?
I was told that the 200 Amp box would not make make things work harder and would make your applances last longer. Can you explain this also.
nhoj 12-02-2012 07:44 AM
K_buz Is it true that if you change from 100 Amp to 200 Amp you will save energy and lower your electric bill?
I was told this by selveal people and I just don't understand how that could be.
They told me that your applances would not work as hard and it would save the wear and trere on them and that would lower your electric bill allown.
I do know by going from 14-2 with ground to 12-2 with ground your wires will stay cooler and not over work themselfs.
k_buz 12-02-2012 08:17 AM
Neither of these two will have any affect on your electric bill.
