100 Amp/150 Amp - Electrical - DIY Chatroom Home Improvement Forum
Old 08-13-2009, 01:20 PM   #1
100 amp/150 amp
Can a 100 amp main panel be changed to a 150 amp main panel simply by changing out the box? I don't want to upgrade to a 200 amp for cost reasons. Someone told me there is a way to upgrade to 150 amp service if the wires are rated correctly. Possible?
pckc12 is offline   Reply With Quote
Old 08-13-2009, 01:49 PM   #2
Rewards Points: 506
Send a message via AIM to theatretch85
Not unless you have 150 amp service you can't. Most times the POCO only sizes the wire to the service provided, they usually aren't known to oversize the wire; ie: 200 amp rated wire for a 100 amp service. You'd have to call your poco and see what size service you have, I know in my area they offered to send out a tech to check the meter/wiring to verify what was installed for my main panel was correct (that it wasn't rated for larger than the meter/wire/service could handle). In my case the existing main panel was 150 amp, and the wire is sized for 150 amp service (no upgrading the extra 50 amps to 200 with out upgrading the wire).
theatretch85 is offline   Reply With Quote
Old 08-14-2009, 02:48 PM   #3
Rewards Points: 58
I would be willing to bet if you went to 200 amp, the utility would not change their service conductors. Especially if the service comes in overhead. But either way I doubt they would change anything on their side. Only you have to get larger wires if yours are to small. The cost between a 200 amp panel and a 100 amp panel, well there may be no cost difference. They sell many more 200 amp panels than they sell 100 amp panels. Check it out. You can use aluminum wire for the service so it would be inexpensive.
The question you must ask yourself is, can I do this job or should I hire someone to do it. The cost is secondary to your health.
J. V. is online now   Reply With Quote
