100 To 200amp Service In Brookhaven, NY - Electrical - DIY Chatroom Home Improvement Forum
Old 10-01-2009, 01:05 PM   #1
Question
100 to 200amp service in Brookhaven, NY
I am located in the township of Brookhaven in NY. We need to run a new line from the meter up to the top of my house where the electric company comes in. I have two licensed electricians looking at this. The lines are now attached to a piece of wood going through the overhang of my roof. The one electrician wants to use a plastic conduit. The other says that to be in code, we have to use a metal one. Does anyone know for sure?
Tom
tomshulski is offline   Reply With Quote
Old 10-01-2009, 01:13 PM   #2
Rewards Points: 160
Most service risers are built with ridged metal conduit. The reasons are obvious. But since you are in NY, I must let someone familiar with your area answer your question.
I would personally NEVER use PVC for a service riser. Strength would be my concern.
If it worked before you worked on it. You did something wrong.
Old 10-01-2009, 01:49 PM   #3
Joe F's Avatar
Rewards Points: 294
You could try calling the power company. They're the ones that will be making the decision to tie in.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 10-01-2009, 01:50 PM   #4
300zx's Avatar
Post
Same here only use Schedule 80 PVC on power poles for Mobile Homes. If the drop is connected to the over hang like you say Pvc is ok where we are not sure in NY. Point of attachment can't be less than (10 ft) above finished grade.
  1. 230.50 (b)(1)Service Cables. Service cables, where subject to physical
  2. damage, shall be protected by any of the following:
  3. (1) Rigid metal conduit
  4. (2) Intermediate metal conduit
  5. (3) Schedule 80 PVC conduit
  6. (4) Electrical metallic tubing
  7. (5) Other approved means
300zx is offline   Reply With Quote
Old 10-01-2009, 02:29 PM   #5
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
If this will be a mast, where the riser supports the service drop, then it must be rigid metal. Many years ago under LILCO the minimum size was 2-1/2".
I assume this is what you are talking about.
Old 10-01-2009, 03:02 PM   #6
Lightbulb
Mast
Yes, this will support the service drop. So far from what I've read, I'm going to fire the electrician who wants to use PVC and $1300 for labor and hire the guy who wants to use a metal conduit and charge $1000 for labor.
Old 10-01-2009, 03:19 PM   #7
300zx's Avatar
Post
If Drop will be supported by the Riser like Speedy Petey said the it needs to be rigid metal. Sounds like you made a good decision.
Tags
200amp service , brookhaven electric
Remodel - Moving from 200 amp service to 320 amps stevedar Electrical 20 11-29-2009 08:14 PM
150amp to 200amp service upgrade... theatretch85 Electrical 30 07-06-2009 05:02 PM
What feeder wire should I use for 200amp service @ 220 feet in 3" conduit? wallstreet Electrical 5 06-17-2009 03:16 PM
Grounding for two service entrances to same house. jogr Electrical 18 09-24-2008 10:31 AM
200 amp panel with a 100 amp service? alexz Electrical 10 07-29-2007 10:00 PM
