10 VAC When Breaker Off - Electrical - DIY Chatroom Home Improvement Forum
Old 01-17-2014, 01:05 PM   #1
hobbsInVancouver
10 VAC when breaker off
Hi. I've been replacing the outlets in my home for years, as I redo rooms I put in the new outlets, the old ones have no ground and are ugly.
Anyway, I noticed the hot wire in a couple of outlets still have 10 VAC charge to them even though the breaker is off. Turning off the breaker above the one with the 10 VAC charge reduced the charge to about 4 VAC. Should I be concerned? Is this indicative of shoddy electrical or something that can happen depending on the layout of the circuits used?
Cheers,
c.
hobbs in vanvouver is offline   Reply With Quote
Old 01-17-2014, 03:06 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 90
Try to put a load on it to see what happens. (incad. bulb should do) Sounds like it may just be phantom voltage.
Old 01-17-2014, 04:48 PM   #3
Rewards Points: 30
What type of tester are you using? Is there a ground available in the box or are you using ungrounded receptacles?
daveb1 is online now   Reply With Quote
Old 01-17-2014, 04:56 PM   #4
dmxtothemax's Avatar
Rewards Points: 5,152
Inductive / capacitve coupling !
dmxtothemax is online now   Reply With Quote
The Following User Says Thank You to dmxtothemax For This Useful Post:
Know A Little (01-17-2014)
Old 01-17-2014, 05:14 PM   #5
Rewards Points: 13,444
Anyone else get the impression he's just swapping out outlets and not using GFI's to make it legal?
daveb1 (01-17-2014)
Old 01-17-2014, 07:11 PM   #6
Rewards Points: 774
http://support.fluke.com/find-sales/...105317_a_w.pdf
Know A Little is offline   Reply With Quote
New Breaker installed- Main Breaker trips novy31 Electrical 14 10-30-2013 08:08 AM
Separate 110 and 220 receptacles on 2-pole 220 V Square D GFI breaker sunrise Electrical 1 05-13-2012 07:27 PM
Outside breaker, inside main breaker panel, so is it a sub? CPF Electrical 29 02-01-2012 10:28 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 11:36 AM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
