10 Cable Junction Box Splice - Electrical - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 09:10 PM   #1
I have a 12 x 12 x 4 metal junction box. I will be using it for twelve #14-2 with ground romex cables. I have to extend the twelve cables because the main panel box was relocated. I have run a complete new cable to each location in the house that was accessable. What do you feel is the best way to splice these twelve cables. I would rather not use wire nuts or those push n lock connectors I have seen in the local home improvement stores. Is there another way to splice them, like some sort of terminal block? P.S., the splice needs to pass an inspection. Thanks for your help !!!
swstx is offline   Reply With Quote
Old 07-05-2010, 09:16 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I like this type of terminal strip. There are 3 different sizes of terminal in this particular picture. They attach to a DIN rail which you would screw down to the back of the box.
Just make sure whatever terminal you use is rated for solid or stranded (whichever you are using) and the size of wire you are using.
Old 07-05-2010, 11:36 PM   #3
Those would make for a professional installation !!! Do you have a manufacture name or part number for them ?
Old 07-05-2010, 11:46 PM   #4
nap
You talking to me?
nap's Avatar
Now you ask the hard questions.
There are a bunch of different manufacturers of that type of terminal. The only place I know of to purchase them is an honest to goodness electrical supply house but I am sure you can get them online as well. never looked for them online though. I just go to a supply house near me.
If you use them, be sure to get end blocks. End blocks generally have a means to tighten them down to the rail so nothing moves. If you don't use then end blocks, you can actuallly slide those terminals back and forth on the rail
you also need the end block to cover the one side that is open as well.
here is a google search page with some of them:
http://www.google.com/search?hl=en&q...-8&sa=N&tab=iw
and lots of pics of them:
http://www.google.com/images?hl=en&q...og&sa=N&tab=wi
Old 07-05-2010, 11:50 PM   #5
Thanks for all the info !!!
Old 07-06-2010, 07:50 AM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,882
Originally Posted by swstx View Post
I would rather not use wire nuts.......
May I ask why????
Speedy Petey is online now   Reply With Quote
Old 07-06-2010, 08:30 AM   #7
Rewards Points: 1,452
Are the wires held in the block by screw clamps or do you just push the wire ends in and they stay in place? If the latter than the connection is the same as the backstab connection on the back of a receptacle or switch unit or the same as the push 'n lock connectors mentioned earlier.
AllanJ is online now   Reply With Quote
Old 07-06-2010, 12:14 PM   #8
nap
You talking to me?
nap's Avatar
you can get either. I prefer the screw down terminals and I believe that is what I posted in my previous post.
yes, they are. Look at the one where you can see the mechanicals of the terminal. You can see the clamping screw which are accessed via the holes on the face of the terminals.
Old 07-06-2010, 10:16 PM   #9
You must also verify that the amp rating of the terminal blocks you buy are high enough for the circuits you are putting them on.
Many times if they fit a 12AWG, they are probably going to be rated at least 20A, and if they fit up to 10AWG, probably rated for at least 30A, but you should check anyway.
Willis
williswires is offline   Reply With Quote
50 Amp Circuit - Splice 6 Gauge Cable to 12-3? jodic Electrical 4 01-23-2010 01:10 PM
NEC Junction Box Conductor FIll: A Single Splice is counted as Two Conductors? Lovegasoline Electrical 7 12-02-2009 11:44 PM
Coaxial Cable Junction Box/Split apriest Electrical 19 07-23-2009 09:33 PM
DIY phone junction box for cable telephone service eastie Electrical 5 06-17-2009 08:45 AM
cable splice kit instead of juction box? pat72 Electrical 18 07-21-2008 06:12 PM
