Old 03-27-2012, 10:25 AM   #1
10/3 wire to 6-20 receptacle
i have a 10/3 wire (red/black/white/ground) that is coming from my house breaker box - it was previously connected to my clothes dryer receptacle, which i don't need anymore. I want to re-purpose the circuit for a few tools that have NEMA 6-20 plugs. 6-20 receptacles have 2 hots and a ground - no neutral.
Can someone give me guidance as to what i should do with the neutral/white wire?
Do i need to do anything other than just terminate/cap the white at the receptacle?
mga56grg is offline   Reply With Quote
Old 03-27-2012, 10:38 AM   #2
Electrical Contractor
rrolleston's Avatar
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Just cap it off with a wire nut so it could be used if it's needed later for a dryer.
Please ask me about my special discount for people that shut up and stay out of my way! With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-27-2012, 01:14 PM   #3
joed's Avatar
Cap it off and change the breaker to a 20 amp breaker. You can't install 20 amp receptacles on a 30 amp circuit.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 03-27-2012, 01:30 PM   #4
many thanks to you both. i will change the breaker
out of curiosity, if my loads max out at 20 amps, why would the 6-20 be a problem on a 30 breaker?
Old 03-27-2012, 03:52 PM   #5
joed's Avatar
Code requires a 30 amp circuit to have 30 amp receptacles. Receptacles must match the breaker except for 15 and 20 amp circuits under NEC. In Canada the even the 15 and 20 amp circuits must match the receptacles.
Tags
10/3, 6-20
Adding GFCI receptacle outdoors Dale Gribble Electrical 2 03-21-2012 02:18 PM
Replacing receptacle with GFCI wiring problem braden Electrical 8 04-06-2011 09:32 AM
Central vacuum - how does the low voltage wire go into the low voltage receptacle? ILIFFE Electrical 4 09-29-2010 11:04 AM
Grounding Dryer Receptacle Montana Sailor Electrical 10 04-20-2010 08:43 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
