10/3 Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 06:14 AM   #16
joed's Avatar
Rewards Points: 12,332
If you insist on using #10 then you only need 10/2.
To use the 10/3 simply don't connect the red wire to anything. Leave curled up in the box with a wire nut on it at each end.
Old 04-20-2013, 06:59 AM   #17
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,942
Exactly Joe. It is painfully simple. Just cap off the red and don't use it.
IMO someone that has to ask a question like this should NOT be touching electrical work without on-site guidance. ESPECIALLY in a (likely) commercial audio/video environment.
Old 04-20-2013, 07:00 AM   #18
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Most 15/20A receptacles are rated for a max wire size of #12. You will need to pigtail some smaller wire to the #10 before landing it on the receptacle.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (04-20-2013)
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 01:02 PM
