10/3 Wire - Electrical - DIY Chatroom Home Improvement Forum
Old 04-20-2013, 12:14 AM   #1
Rewards Points: 12
10/3 wire
Hello;
How would one wire a 20a 125v outlet with 10/3 plus ground since there would be a second hot ( red wire)
Thank-you
BlkNotes is offline   Reply With Quote
Old 04-20-2013, 12:34 AM   #2
Always learning...
fetzer85's Avatar
Rewards Points: 262
Do you know a standard 20a circuit only calls for 12/2 wiring?
fetzer85 is offline   Reply With Quote
Old 04-20-2013, 12:37 AM   #3
Rewards Points: 12
Yes I do, but this is being used in audio & video application with dedicated lines.
Old 04-20-2013, 12:41 AM   #4
Always learning...
fetzer85's Avatar
Rewards Points: 262
...maybe I'm missing something but I still don't understand why you'd have to run 10ga wire to a 20a receptacle?
Old 04-20-2013, 12:44 AM   #5
Rewards Points: 6,652
Only need 12/2. 10/3 is not going to do anything for you, unless you have the need for 240v 30amp circuit, that needs a ground and Neutral.
I would also stay away from MWBC (Multi-Wire Branch Circuits), with anything that has to do with A/V gear. Also, unless you know what you are doing when it comes to electric, you can end up causing a whole lot of issues with ground loops, if you do not do it correct.
Old 04-20-2013, 12:49 AM   #6
Rewards Points: 12
Using 10/3 has to do with less voltage drop and auditory and visual improvement.
No multi branch circuits, just one line per outlet.
Old 04-20-2013, 12:55 AM   #7
Always learning...
fetzer85's Avatar
Rewards Points: 262
Hmm...I don't know enough to speak on that topic, but if you insist on using 10ga wire then use 10/2 - or did you already buy the 10/3?
Old 04-20-2013, 01:04 AM   #8
Uhm no it does not. Unless you are running the wire over 1000 feet, which in most outside venues, it is a stranded wire from the board to the amps, and amps to the speakers, you are not going to see any of that in a home, running 12/2 on a 20amp, or 14/2 on a 15 amp for normal household outlets.
Really do not know where you dug up that piece of garbage about having less voltage drop, along with auditory & visual improvement, because the power wire is a larger gauge. Again, the larger gauge is only for use between the amps & speakers, if pushing a large amount of watts at concert levels, or having Motorhead play live at your place.
Old 04-20-2013, 01:06 AM   #9
It is a BS topic, that the OP is just throwing around, without knowing the real reason why larger wiring sizes are used, which is mostly in commercial operations, when using 240vAC amps, vs. 120vAC amps.
Then of course, I wonder if they know the difference between what a single phase & three phase amp is, and why they are used.
Old 04-20-2013, 01:15 AM   #10
Rewards Points: 12
All I was asking is how to wire a 20a 125v outlet with 10/3 + ground wire.
I did not want a debate about electrical theory.
Old 04-20-2013, 01:31 AM   #11
What did you expect, when you asked if you should use 10/3 for a 120vAC circuit. Plain and simple answer, is that it is overkill, and not needed for what you are doing.
Old 04-20-2013, 01:37 AM   #12
Rewards Points: 258
Considering this is the preamp/video power wire better audio/video is not going to be a factor. Unless this is a post amp power feed. Don't think it is. Draw us a picture of the layout of the system and were this 10-3 wire is connected both ends
redman88 is offline   Reply With Quote
Old 04-20-2013, 01:44 AM   #13
Even Postamp in a residential setup, it is not going to change the clarity of the sound, or make the picture better than the Blu-Ray, DVD, stream from online, or Ripped video.
Old 04-20-2013, 05:45 AM   #14
Rewards Points: 1,494
Do not bare the end of the red wire. Curl up that wire in the box and leave it unused (both ends).
Connect the black wire to a gold screw on the receptacle (side with the smaller prong slot) and connect the white wire to a silver screw on the other side.
One disadvantage of 10 gauge wire is that it is quite stiff and you will have to use a lot of care to get the receptacle into the box.
Suggest that, at the panel, you connect a short length of 12 gauge wire to the breaker and to the black wire of the 10/3 instead of connecting the 10 gauge wire directly to the breaker. This warns someone working in the panel later that there is a 20 amp component (an ordinary receptacle) on that circuit and that that circuit may not be connected to a 30 amp breaker at a later date.
Old 04-20-2013, 05:54 AM   #15
Thread killer
Rewards Points: 272
Greg, you'll have more luck convincing the pope that God isn't real than an audiophile that wire size, colour, shape, placement, etc, doesn't make an audible difference. No amount of actual tested science will convince any of them. Their golden ears can hear what the most expensive test equipment can't.
You can have it good, fast or cheap. Pick two.
Canucker is offline   Reply With Quote
The Following User Says Thank You to Canucker For This Useful Post:
gregzoll (04-20-2013)
Honeywell vision pro, fan always on? and True Steam problem c5sb HVAC 6 06-19-2012 09:08 PM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 01:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 01:02 PM
