10/3 UF Or 6/3 UF? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2013, 07:40 PM   #1
10/3 UF or 6/3 UF?
Hello, I am having electric ran to my shed from my house SEP. In the shed I plan on at most at once time running two portable heaters(2 x 1500w) an air compressor(1500w) a radio(10w) one power tool (100w) and some lighting.
I have heard so many different opinions from different people as to what uf cable I should purchase. Im not so concerned with price that when I fire up my planer my lights will dim while two heaters are keeping it warm and my air compressor happens to kick on.
The shed is a 12 X 16. Can somebody please shed some light on this. Some people say 6/3 is overkill while others say 10/3 is not enough.
Chow Ding is offline   Reply With Quote
Old 03-07-2013, 07:56 PM   #2
Rewards Points: 12,802
Think about it, if you try to get by with just 10-3 what do you do when it does not work out?
Cheaper to do it right the first time.
So what if you have more power then you need.
Old 03-07-2013, 08:01 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by Chow Ding View Post
I have heard so many different opinions...
The WORK involved is exactly the same.
The marginal difference in cost for the heavier wire will soon be forgotten.
That said... I'd suggest you use pipe and (#6) wire.
Even that add'l cost will soon be forgotten.
The Following 3 Users Say Thank You to TarheelTerp For This Useful Post:
jbfan (03-07-2013), mpoulton (03-08-2013), NJMarine (03-08-2013)
Old 03-07-2013, 08:52 PM   #4
Rewards Points: 948
Okay, what is SEP? I will wildly guess service entry panel?
Anyhow, you are using about 25a. Unless your shed is more than 250' from your panel, #10 is fine.
Toller is offline   Reply With Quote
Old 03-07-2013, 08:58 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Disagree...I don't know how anyone would say a 30A feeder would be enough knowing what is planned on being used.
Planer
Air Compressor
2 X 1500W heaters
With the heaters on, either one of the other two could trip the circuit at start up.
50A minimum, but I would recommend 60A
Old 03-07-2013, 09:32 PM   #6
Thank you all so much. I was preferring the #6 but my electrician friend has been insisting#10 will be fine. Just doesnt make sense to me.
Old 03-07-2013, 11:03 PM   #7
Rewards Points: 948
Planer
Air Compressor
2 X 1500W heaters
He didn't mention a planer. His total came to about 20a, but since it was unbalanced I rounded up to 25a.
Old 03-07-2013, 11:09 PM   #8
k_buz's Avatar
I knew I wasn't imagining it.
Old 03-08-2013, 12:17 AM   #9
Rewards Points: 192
He also did not mention if these loads are 120 or 240 loads. If they are 120 loads they will be split between the phases.
I would always error on the side of the larger wire. As stated in an earlier post, the work is the same.
bcgfdc3 is offline   Reply With Quote
Old 03-08-2013, 01:48 AM   #10
Rewards Points: 1,016
____________
Vince
Old 03-08-2013, 05:31 AM   #11
Electrician
Rewards Points: 150
In general, for copper, the double pole breaker sizes at the SEP would be:
10/3 with ground UF or 4x#10 in pipe- 30A
8/3 w/ g UF - 40A
3x#8 w/ #10 ground, in pipe - 50A
6/3 w/ g UF - 60A
3x#6 w/ #10 ground, in pipe - 60A
3x#6 w/ #8 ground, in pipe - 70A
Assuming individual wires are rated THWN or better.
Glennsparky is offline   Reply With Quote
Old 03-08-2013, 06:20 AM   #12
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I would also use conduit. Much better in the long run. I have replaced many ufb installations. Even ones buried in sand. Somehow a rock always works its way to the wire and wears a hole in it.
Sent from my iPhone using DIY Forum
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 03-08-2013, 06:44 AM   #13
Rewards Points: 309
Do the above without another thought. The fact that you have a planer, a compressor, and who knows what else, indicates that you need a SHOP, not an outbuilding. You will inevitably add bigger and better tools, get better heaters, or want A/C in the summer.
I have a fairly large shop, and I assure you I have never been sad that I didn't have to worry about running a bigger and badder tool! I have upgraded over the years from basically an empty room to a 7 1/2 HP compressor, two 250 amp MIG welders (50A each @240VAC), a 2 HP lathe, a 3 HP mill, and a new heavy duty planer that draws [I think] 16 amps @240 volts.
Do not skimp. Easy to have too much, not easy to have too little. And since you indicate that cost is secondary, always go as big as you can afford.
Nuff said.
al_smelter is offline   Reply With Quote
Old 03-08-2013, 07:14 AM   #14
Rewards Points: 1,214
Yes he did re read it.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
Old 03-08-2013, 04:32 PM   #15
Rewards Points: 196
Just the fact he wants to run 2 heaters is enough to make an easy decision on going with #6 over #10. #10 only gives you a max of 30 amps as #6 gives you 60 amps. And you will be very surprised a few years down the road when you want to add even more tools and other uses of electricity to that building. Like others have sad... go bigger. You wont have to worry about not having enough power down the road.
Jason34 is offline   Reply With Quote
10/3 or 8/3 for generator AdamBNYC Electrical 3 12-03-2012 03:04 PM
conduit for 10/3 interior niche Steve Burke Electrical 4 01-29-2012 12:16 PM
Short ciruit with Romex 10/3 cable and cable connectors virago Electrical 21 10-07-2011 09:01 AM
Splitting 10/3 John J Oswald Electrical 4 05-24-2011 06:16 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 02:02 PM
