#10-3 Cloth Romex With #14 Ground Safe? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 01:39 PM   #1
langless28's Avatar
Rewards Points: 152
#10-3 cloth romex with #14 ground safe?
just got a washer and dryer and was wondering if the existing wire would suffice? the cloth romex seems to be in ok shape, it just has a #14 ground, is this ok? i will be using the a 14-30R receptacle.
also i am not sure if "cloth romex" is the right term, its early 60's romex type wire and it looks like it has that tar cloth type stuff as the jacket.
langless28 is offline   Reply With Quote
Old 12-03-2011, 03:28 PM   #2
Rewards Points: 6,652
Personally, I would replace it. If you were to hook a megger up to it, it would come back that the insulation inside has most likely broken down. For current code, you need to have the wash machine on a dedicated 12/2, 20amp circuit. That means that it can not feed anything else, but a wash machine & gas dryer if you have one. You can though have a second or more circuits for convenience in that space, which those would fall under the SABC (Small Appliance Branch Circuit) catagory.
Old 12-03-2011, 03:53 PM   #3
langless28's Avatar
Rewards Points: 152
what is this megger thing? yes i do have the washer on a dedicated 20 gfic circuit. i was just concerned about the dryer wire. also on the dedicated washer circuit; i cant even hook a switch and 4' shop light up to the circuit for the washer dryer area?
Old 12-03-2011, 03:57 PM   #4
Megohmmeter is a special type of ohmmeter used to measure, or rather test, the insulation resistance of insulators. Insulators have electrical resistance in the range of millions of ohms compared to conductors which are measured in ohms. Insulators need testing for their insulation strength at the time of commissioning and as part of maintenance for electrical equipments and installations. For this purpose special ohmmeters called megohmmeters which can provide high voltages (typically in ranges from 500V to 2 kV) at specified current capacity are used. The minimum insulation tolerated are in the range of 1 to 10 mega-ohms, depending on the standards referred to.
http://www.ehow.com/how_5526264_use-...on-tester.html
Attic wiring - ceiling lighting uses 14/2 cable without ground darlingm Electrical 3 11-29-2011 09:01 AM
Attach #4 Copper to Neutral/ Ground Lug Sierevello Electrical 3 01-29-2011 01:04 AM
Wiring an outlet using both ground screws instead of pig-tailing together. cabber24 Electrical 5 08-26-2010 08:40 AM
To ground or not to ground, that is the question cartalker Electrical 8 10-18-2008 10:12 AM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
