10/2 Air Conditioner Wiring - Clarification - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Closed Thread
Old 05-14-2013, 08:12 AM   #16
An old Tradesmen
Rewards Points: 6,876
Originally Posted by usair View Post
I have never found one that needed less than a 30 could you give the model that takes a 15.
York TCGF18S41S3 Min over current device amps 15, max over current device amps 20.
The 2, 2.5 and 3 ton in that model line has a min amp device of 20. the 3.5 has a min amp of 25. The 4 ton is min 30, and the 5 ton is min 40.
beenthere is offline
Old 05-14-2013, 11:50 AM   #17
JW
mm11's Avatar
Rewards Points: 606
several "codes" I can think of.
NM cannot be used outdoors even in conduit thhn will neeed to be ran in conduit if used. UF can be used without conduit if allowed by local jurisdiction.
Any location outside, even in raceway, requires the use of conductors rated for wet locations. Using THHN would be a violation if installed outside.
mm11 is offline
Old 05-14-2013, 01:29 PM   #18
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
THHN is dual rated THHN/THWN.
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline
Old 05-14-2013, 01:43 PM   #19
JW
mm11's Avatar
Rewards Points: 606
Using THHN outside is a violation. It's rated for dry and damp locations only, as I'm sure you know. The comment I responded to had no reference to multi-rated wire, such as MTW/THWN-2/THHN, which is acceptable to use outdoors.
mm11 is offline
Old 05-14-2013, 02:00 PM   #20
Rewards Points: 746
Not if it doesn't say THWN.
Mark
busman is online now
Old 05-14-2013, 02:49 PM   #21
electures's Avatar
Mark
And how often do you see straight THHN? Almost never.
The Following User Says Thank You to electures For This Useful Post:
Speedy Petey (05-14-2013)
Old 05-14-2013, 03:01 PM   #22
Rewards Points: 150
Oooops I forgot this is a forum and I should have been VERY clear we dont buy THHN that is not dual rated as a matter of fact I am not sure if it is available without a special order. Next time I will be sure and post DUAL rated THHN must be in conduit.
usair is offline
Old 05-14-2013, 03:21 PM   #23
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,948
Not true. Not all outdoor raceways are wet locations.
All underground outdoor raceways are though.
Speedy Petey is offline
The Following User Says Thank You to Speedy Petey For This Useful Post:
electures (05-14-2013)
Old 05-14-2013, 03:22 PM   #24
Mark
I'll ask the same thing. When was the alst time you bought new THHN that was not dual rated with THWN??
It is so petty when folks just HAVE to point this out when it is a complete non-issue.
Old 05-14-2013, 03:53 PM   #25
I've only been on this forum for a few weeks. I came to get reasonable answers/ideas from reasonable people. However, this forum seems more of a school yard mentality (my dad's better than your dad).
Anyone know a forum where I don't have to filter though all this bs?
Huck2013 is offline
Old 05-14-2013, 04:07 PM   #26
Might I suggest you get a thicker skin or possibly be less picky?
I don't know what thread you are reading but in this one all I see is adult discussions about technical issues.
Can you point out the "my dad's better than your dad" stuff you are talking about?
Old 05-14-2013, 05:20 PM   #27
electures's Avatar
That's it. I'm getting the popcorn.
The Following 2 Users Say Thank You to electures For This Useful Post:
Kyle_in_rure (05-14-2013), usair (05-15-2013)
Old 05-15-2013, 05:57 AM   #28
Electrical Contractor
Philly Master's Avatar
Rewards Points: 516
what question do you have that was not answered ??
but .. here ..
120 v is 1 hot to 1 neutral ....
240 is 2 hots .. no nuetral needed in its purest form ... ( so 10/2) would be fine ..
some things need the neutral wire to run the lower voltage (120v ) stuff so 10/3 is used ie your dryer and your stove, the cotrols, timers, clocks, etc are 120 v
Philadelphia Master Electrician-Generac Dealer
Philly Master is offline
Old 05-15-2013, 06:10 AM   #29
Rewards Points: 746
Well, we'll just have to agree to disagree. I'm sure somewhere in the US, there are still spools of THHN that is not labeled as THWN. I agree that this is a non-issue for professionals for two reasons:
1) We mostly only use newly purchased materials and probably don't have a spool of wire that is more than a few years old.
2) We know better.
My post was directed at the DIY, who is more likely to try to re-use materials. How many times on this forum have we heard things like "Is there a way I can use this wire, it's what I already have?" I just wanted to be clear that people need to read the markings on their wires to know that can be used for.
Mark
The Following 2 Users Say Thank You to busman For This Useful Post:
mm11 (05-15-2013), Philly Master (05-15-2013)
Old 05-15-2013, 10:41 AM   #30
JW
mm11's Avatar
Rewards Points: 606
If the raceway is exposed to weather, it's a wet location. I can't think of a raceway I've ever run outside that wasn't exposed to weather for at least some portion of the run.
mm11 is offline
Closed Thread
Critique my Panel Wiring Please Ocelaris Electrical 14 03-16-2013 01:10 PM
Extending Wiring Before Circuit Panel... Zeigh Electrical 3 03-02-2013 07:36 PM
AC wiring question? Ralph III Electrical 4 03-04-2012 10:52 AM
AC wiring questions? Ralph III HVAC 0 03-04-2012 10:12 AM
electric wiring in house remodel wis_remod Electrical 6 04-02-2009 02:40 PM
