10/2 Or 10/3 - Electrical - DIY Chatroom Home Improvement Forum
Old 11-30-2008, 08:26 AM   #1
10/2 or 10/3
I joined this forum today, after searching for answers to wiring questions. As part of finishing my basement, I installed a 250V, 16 amp, 4000 watt electric heater. The manual calls for 10 gauge wiring. The heater has black and red wires, as well as the ground screw. Can I use 10/2, and connect the red to the white, or do I have to go to 10/3, leaving the white unconnected. The run is about 100 feet from the box. If it matters, I am in PA.
Thanks in advance.
SR996 is offline   Reply With Quote
Old 11-30-2008, 08:36 AM   #2
Rewards Points: 2,350
Thanks in advance.
Yes, you can use 10-2. Color the white wire at each end with tape or a marker to indicate that it is a hot wire.
Old 11-30-2008, 09:02 AM   #3
Thank you for your quick reply. At 100 feet, the difference in price between 10/2 and 10/3 is quite substantial.
Old 11-30-2008, 03:06 PM   #4
why would 10 gauge be needed? why would 12 gauge not suffice?
joey b is offline   Reply With Quote
Old 11-30-2008, 05:32 PM   #5
Because you must size the conductors to 125% of the load. Which is slightly more than 20 A, so you must upsize to #10.
Old 11-30-2008, 06:46 PM   #6
horn4522
It would work just make sure to recode the wire.
horn4522 is offline   Reply With Quote
installing a subpanel from 10/2 wire. d_skutnik Electrical 7 10-08-2008 05:35 PM
20 amp breaker on 10/3 wire Duane 70 Electrical 6 09-16-2008 01:02 PM
Rough In Assistance for h-f-l-nl & sink GFI from single 10/2 feed mntnvew Electrical 4 03-14-2008 10:30 AM
Can i add a subpanel fed by 10/2 wire? qst4sno Electrical 25 04-25-2007 05:14 AM
