1 Switch, 2 Lights And One Light Stopped Working? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-23-2013, 05:07 PM   #1
Gkt
1 switch, 2 lights and one light stopped working?
Ok, I am new to this so bear with me. I am usually pretty good at soucing things out except electrical. That being said, in my bathroom I have 2 lights attached to one switch and one light has stopped working? The light that mysteriously stopped working is a 4 bulb halogen light and one bulb had been flickering for awhile. Bulb has been replaced and it still won't come on?
Bathroom remodelled w/new wiring and fixtues 2010
New breaker panel complete w/new wiring 2010
Any ideas or solutions, please help
thanks
Gkt is offline   Reply With Quote
Old 05-23-2013, 05:22 PM   #2
Licensed electrician
Rewards Points: 1,288
Do you feel comfortable checking the connections behind the light that does not work?
Old 05-23-2013, 05:32 PM   #3
Gkt
Sure I guess if you could walk me through it? The light is mounted into the ceiling, I have to dismantle the light ( no issue) and then if you could tell me what I looking for?
Old 05-23-2013, 05:49 PM   #4
You could be looking for a loose connection or a wire that has come out of the wire nut.
Before all that, have you checked the bulb?
Old 05-23-2013, 06:00 PM   #5
joed's Avatar
Rewards Points: 12,022
Is it a lower voltage halogen light? The problem could be the transformer.
Old 05-23-2013, 06:06 PM   #6
Gkt
I have replaced only one bulb... maybe I should replace all of them. G9 40 watt
Old 05-23-2013, 06:07 PM   #7
Gkt
How would I check the transformer?
Old 05-23-2013, 09:56 PM   #8
You would need a meter to check for voltage on the output.
Old 05-24-2013, 09:05 AM   #9
joed's Avatar
G9 40 watt comes up as a 120 volt lamp. There will not be a transformer if that is true.
Look for a loose or open connection or perhaps a burnt socket. What do the pins look like on the lamp you removed? If they are burnt then the socket is burnt as well.
