1 Gang Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 09:18 PM   #1
1 Gang Boxes
Whats the difference between 20 and 22.5 cu. in. 1 gang boxes??? When and how does 2.5 cu. in. come into play???
These are the two boxes available at HD...
MisterSteve is offline   Reply With Quote
Old 03-07-2012, 09:29 PM   #2
Ravenworks's Avatar
Wire rule,more room more wires.
Ravenworks is offline   Reply With Quote
Old 03-07-2012, 09:30 PM   #3
Licensed electrician
Rewards Points: 1,876
The bigger box is deeper and allows more wires to be installed in the box.
Old 03-07-2012, 09:39 PM   #4
So a simple 12/2 in and 12/2 out receptacle would not require the 22.5 cu. in. box, correct?
Old 03-07-2012, 09:46 PM   #5
Two 12-2 cables + a receptacle would have a conductor count of 2+2+1+2 for a total of 7 allowances of 2.25. Your box would only need to be 15.75 cubic inches or larger.
In the explanation above the ground only counts once, the device counts as two. No allowance was made for a clamp.
frenchelectrican (03-07-2012)
Dual Bath Vanity GFCI - Single Gang Boxes or a Single Two Gang Box? WoodmanFL Electrical 2 12-11-2011 07:39 PM
Dimmer switches and gang boxes Badfish740 Electrical 9 03-01-2011 08:55 AM
Installing gang boxes for tiled backsplashes chronojosh Electrical 5 02-13-2011 02:10 PM
keeping 3 gang boxes from moving titan7 Electrical 7 09-01-2010 04:26 PM
Increase to double gang boxes... jamiedolan Electrical 20 10-17-2008 12:21 PM
