1 Gang Box Rececessed In 2 X 4? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 10:17 PM   #1
1 Gang Box rececessed in 2 x 4?
Hey all looking to add some tracking lighting, but I have a "unique" situation.
I have two rooms, divided by an interior 2x4 wall. Now this wall has an open section at the top where light/sound can pass from one room to the other. So obviously non-load bearing. The opening at the top of the wall is really just an architectural accent. The opening is about 8' wide, 3' tall from the top of the wall to the vaulted ceiling.
I want to add some up lighting to bounce light off the ceilings of both rooms to try and brighten things up as our walls are a darker color. My thought its to add track lighting along the top 8' length of this 2 x 4 wall. I can then add lights and aim them as I wish. Now, this will be installed up-side-down from your typical track lighting installation which isn't a big deal however creating a proper electrical box to connect the lighting to will be a problem as I don't have any existing electrical supply in the area.
I have an electrical switch on the same wall already which controls existing outlets for lamps. I would like to run new wire from the switch to the top of the 2 x 4 wall where I can wire the track lighting into. Pretty straight forward but I'm not sure what the proper electrical box would be. Because the track lighting will rest directly on the 2 x 4 (add 1/2 sheet rock too) I can't install an electrical box like you normally would (side of the 2 x 4). I would need to notch the 2 x 4 in the center to install a 1-gang box (opening of the gang box would face the vaulted ceiling). Now normally you could just buy an old work box, cut a hole in your sheet rock and mount the electrical box by clamping it against the sheet rock, however the 2 x 4 is much thicker so I'm not sure if such a box exists.
Anyone have some suggestions? Or is this something completely against code?
Thanks!
Thisgrub4u is offline   Reply With Quote
Old 12-28-2013, 10:33 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Purchase an end feed for the track, it does not require a separate electrical box.
Old 12-29-2013, 09:05 AM   #3
Licensed electrician
Rewards Points: 1,780
Originally Posted by stickboy1375 View Post
purchase an end feed for the track, it does not require a separate electrical box.
x2. .
Old 12-29-2013, 09:10 AM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I would make sure that the track you pick is rated to be installed "face up". I can see issues arising from exposed live parts in the track. If I'm not picturing your plan correctly, I apologize.
Old 12-29-2013, 09:17 AM   #5
The live parts would be no more exposed then when ceiling mounted. The mounting is simply rotated.
Old 12-29-2013, 09:27 AM   #6
k_buz's Avatar
I understand that, but it's hard for anything to fall into the track when it is mounted on the ceiling...and listings can be quite specific.
Old 12-29-2013, 09:46 AM   #7
I would feel pretty safe with it mounted on top of a wall that except for dust not much would have a chance to fall into the track.
Old 12-29-2013, 09:48 AM   #8
k_buz's Avatar
Believe me, I know what you are saying. I was one of the ones saying that that receptacle, face up, under the sink drain was legal.
The Following User Says Thank You to k_buz For This Useful Post:
stickboy1375 (12-29-2013)
Old 12-29-2013, 10:25 AM   #9
Thanks for the feedback, didn't realize the end feed was an option. When I asked at the hardware store he certainly didn't know this either! It's my first time with track lighting. I was also thinking about the face up orientation, only concern I had was dusts build-up over many years, so I thought about putting tape over the track once all the lights where positioned just to mitigate this.
I may actually mount the track lighting on the side of the wall now, mounted it temporarily last night to see the light disbursement and while it works, the result isn't quite what I had imagined.
Old 12-29-2013, 10:27 AM   #10
E2 Electrician
IMO, the track is fine to be mounted face up, i've yet to come across a manufacture saying otherwise.
Old 12-29-2013, 10:29 AM   #11
k_buz's Avatar
I haven't had the opportunity to check for myself.
Old 12-29-2013, 11:23 AM   #12
Sure, like anyone reads the instructions.
The above is said in jest and in no way is meant to reflect stckboys ethics or work practices.
Old 12-29-2013, 11:24 AM   #13
E2 Electrician
Ha, true story!
3 gang box oriented "portrait"? miamicuse Electrical 18 12-23-2013 05:31 AM
Garage single gang box GFCI w/12 conductors rstyszko Electrical 9 06-08-2012 03:17 PM
There is no two gang mud ring & wall plate for a CENTERED switch? miamicuse Electrical 4 06-07-2012 05:34 PM
wiring a single gang and 3 gang box from one source twinkietrucker Electrical 4 02-17-2010 07:01 AM
2 gang old box, made into 3 gang, off center?? fabian Electrical 9 01-15-2010 09:46 AM
