1 Electric Baseboard Is Out, Advice? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2013, 10:01 AM   #16
Ok... Next step...
I turned off the breaker.
I removed the wire nuts in the photo attached. I did not detach the wires from each other as I did previously.
I turned on the breaker.
I turned on the thermostat, set it to 80F.
I tested with my multimeter. Touching the black probe to the left set of wires (black/black) and the red probe to the right set of wires (black/white)
I got 240V as I believe I should.
So this means the heater itself is no good, if no heat is coming out and there is good power to that spot. Correct?
agentphish is offline   Reply With Quote
Old 01-05-2013, 03:38 AM   #17
Electrical Contractor
kbsparky's Avatar
Correct.
You either have a bad element, or hi-temp sensor.
Replace the unit.
-KB
Old 01-05-2013, 09:35 AM   #18
Rewards Points: 1,192
Originally Posted by agentphish View Post
I have attached some photos at this time. I think it's the baseboard unit itself. What do you guys think?
Also to be clear the small amount of voltage I am getting in the one pic is the same as I am getting at the thermostat.
I think I think some things are better left to the "Seasoned Experts".
bobelectric is offline   Reply With Quote
Old 01-05-2013, 09:49 AM   #19
bobelectric, what is that supposed to mean exactly? Doesn't sound like a nice comment to me.
I believed the unit itself was bad. It looks like I may be correct based on feedback here.
Electric baseboard heat/relay switch issues Buzzard67 HVAC 4 10-31-2012 12:32 PM
Electric Baseboard Convection Heater - Buying House Info? olimits7 HVAC 4 10-24-2012 09:45 AM
Electric Baseboard Heater Wiring Help ryanb4614 Electrical 19 09-28-2012 07:30 PM
Electric baseboard VS Heat pump Mattme123 HVAC 20 09-21-2012 08:41 PM
Electric Baseboard Heater Problem goombie Electrical 9 12-23-2008 12:13 AM
