~1.5V/2.3V From What Source? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-05-2011, 11:26 AM   #1
~1.5V/2.3V from what source?
I'm removing a rats nest of duct tape and wire run from a home exterior wall to what can be loosely called a shed. I only found one UF romex at 120, so that should be easy enough to box up, but there's also a set of three stranded #14 wires that are duct taped together. I'm getting ~1.5V and ~2.3V between a couple of the wires, and there's a string of what appear to be low voltage lights nearby. Is that voltage coming from those, or could it be coming from some of the spa equipment that still has an active and separate 120 line run to it?
omgwtfbyobbq is offline   Reply With Quote
Old 06-05-2011, 01:10 PM   #2
Missouri Bound's Avatar
If those lines are parallel to the active spa line, you could be reading phantom voltage. Are you using a digital meter or analog meter?
Old 06-05-2011, 01:17 PM   #3
That must be it. Too much impedance w/ my DMM causing unduction or capacitance in the other wire. Are the different voltages between different wires indicative of differing impedance/etc in the three inactive bundled wires, and is there any reason why one pair still reads zero voltage?
As a side note, w/ the dmm I also get about 1V less at the plugs on circuits that have a lot of receptacles/lights than one dedicated circuits (dishwasher, garbage disposal, ect), is this normal?
Edit- Doh! Of course it is since those branches are a lot longer than the short runs to the appliances.
Old 06-05-2011, 07:40 PM   #4
Sounds like you've got it figured out. Good luck with future projects.
Old 06-06-2011, 02:54 AM   #5
Semi-Pro Electro-Geek
Rewards Points: 2,928
Hey, somebody who actually understands phantom voltage readings! You got it. Try a light bulb in parallel with your meter, or a meter with a "low-Z" option.
mpoulton is offline   Reply With Quote
installing light fixture with no ground from source - help! lswenn Electrical 1 03-29-2011 06:52 AM
where to draw a source for a light fixture/switch snucky Electrical 12 07-26-2010 12:31 PM
Undercabinet lighting power source? Ideas? PDubs Electrical 7 01-28-2009 04:37 AM
Three electricans said it was impossible! Tom Electrical 35 04-29-2006 05:06 PM
