1.5 Watt Vrs 6 Watts? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-01-2013, 05:00 PM   #1
funfool's Avatar
Rewards Points: 534
1.5 watt vrs 6 watts? [solved}
Is the fan motor for the condenser on my old clunker fridge. I went to grainger for a replacement and what they were finding all listed a different mounting bracket system.
Then out of curiosity, He said, Let me grab one and look at it.
Turned out to be exactly what I needed and simply had a universal type mounting with more options.
So I said I will take it.
I get it home and fan blade installed and ready to hook it up, install it.
I notice that it is 115v 50/60 HZ 0.42 amp 6 watt
While the old one is 115v 50/60 HZ 0.25 amp 1.5 watt
We were just grabbing one to look at and I know they do have a 2 watt model, will really mean waiting until tomorrow to return it and will just be a pia.
What can I expect the difference to be with higher amp and watts?
Can I just use the one I have?
funfool is offline   Reply With Quote
Old 04-01-2013, 05:28 PM   #2
Rewards Points: 3,130
Trivial difference. You can use it.
The Following User Says Thank You to md2lgyk For This Useful Post:
funfool (04-01-2013)
Old 04-01-2013, 05:43 PM   #3
funfool's Avatar
Rewards Points: 534
Thanks, I really felt it would be ok, Just wanted to hear it from someone else.
I do know they have something closer to watts and amps.
I already had to take off from work early today to remove it and pick up the new motor.
Would mean taking more time off tomorrow to exchange it.
I called grainger and they said was not a electrician, but thought with higher amps it may use a little more electricity.
Using a 150 watt bulb in an outdoor lampost that says max 100 dan123 Electrical 8 08-31-2012 09:37 PM
15.2 watt ballast /20 watt bulbs pbr2424 Electrical 0 08-15-2012 02:55 PM
Demand Load Calculations sirsparksalot Electrical 6 05-10-2011 05:42 PM
timer requires a 40 watt min. load, I only have 10...now what? glassbird Electrical 3 08-18-2010 11:32 AM
Watts up with HD's product line? Ultrarunner2017 Plumbing 2 03-25-2009 10:10 PM
