Old 03-02-2011, 04:51 PM   #1
1.5" deep wall can I use BX??
Hi had to cut into a section of 2 x 6 wall to recess a 5' wide by 6.5' high with a header and then reduce that area under the header to a wall cavity thickness of 1.5 and 16" OC. It is an area under some steps that was designed for a washer and dryer but the builder said he could make it a 1/2 bath (toilet and sink). Well he screwed this up too. Wall to close so standard sink won't fit. I got hold of a old gas station sink and it is better but I still had to reduce the size of the 2 x 6 wall. So I want to add some electric to the wall so I have a medicine cabinet above the sink and need an outlet on this wall. I asked the electrician here and he said NO PROBLEM!!! I can use Romex I think I have to protect the wire from puncture and shorts.
So, who is right and will BX be adequate of do I have to try and run EMT or what??
suggestions, advice, recommendations
thanks
Walt
walt1122 is offline   Reply With Quote
Old 03-02-2011, 05:42 PM   #2
Licensed electrician
Just follow this graphic from Mike Holt and keep the cables 1 1/4" away from the framing. There are standoffs made to hold the cables in place.
Old 03-02-2011, 06:58 PM   #3
Hi Jim Post, great drawing. This does help I hadn't looked at it that way but it makes sense. The use of furring strips on all those basements and the sheetrock placed so close to the wall. I will search out the standoffs. Now, what to do with the BX??
thanks
Walt
Old 03-03-2011, 01:41 AM   #4
" Euro " electrician
frenchelectrican's Avatar
You can use the BX cable it the same rules as Jim Port posted the photo with standoff.
However there one issue with BX cable I am not sure which type of BX cable due there are few diffrent style of BX cable which it can be MC { metal clad } so the methold of use them will varies a bit as long the basement wall is very dry with no moisture show up { a quick vapour barrier test will show up on that one } then any type of cable or conduit will work.
Most of my furring strips sites which I have deal I hardly ever touch NM at all most case I run in conduit { useally EMT unless you have damp wall then I will switch over to PVC if that the case }
Merci.
Marc
The Following User Says Thank You to frenchelectrican For This Useful Post:
walt1122 (03-03-2011)
Removing a wall with no ceiling joist above it i77ac_10 Building & Construction 2 01-05-2011 01:30 PM
turning a half wall into a full wall lcmakeup Building & Construction 4 01-04-2011 08:22 AM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
