1 & 3 Phase Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 01-04-2009, 09:22 PM   #1
1 & 3 phase questions
hi i have a conveyor dryer that i picked up, it is currently wired for 3 phase but the guy i got it from said it can be wired to single phase.
how would i re wire for single phase untill i get my phase converter?
527ink is offline   Reply With Quote
Old 01-04-2009, 09:28 PM   #2
Whatamess
You have to have the converter.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 01-04-2009, 09:30 PM   #3
DIYer
That's not necessarily true Tazin...
If the motor is single phase but the heating elements are crossing the phases (likely), then it would be possible to rewire it.
However we don't have anywhere near enough information to help you do it 527.
Gigs is offline   Reply With Quote
Old 01-04-2009, 09:40 PM   #4
i have a schematic,its a lil hard to read(old) that i will try and upload to give you a better idea
Old 01-04-2009, 09:49 PM   #5
Old 01-04-2009, 09:53 PM   #6
Old 01-04-2009, 10:42 PM   #7
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
from what I see, that drawing is for a single phase hook-up but the connections look like it requires a neutral as well.
doesn't it even say 230 1 phase and 208 1 phase in the llower right hand corner of the print?
It seems to require a neutral but that drawing sure bothers me. It looks like the power through 1 fu then goes through (?)#4 (another fuse ritght beside 1 fu) then it appears the neut attaches to the load side of the same fuse (#4) after it passes through what looks to be a switch.
Do you see what I am seeing or are my old eyes decieving me?
whoops, nevermind. It was my eyes. I see where the neut passes over the other conductor.
do you have a different drawing that would show a 3 phase connection?
Old 01-04-2009, 10:46 PM   #8
ya it says 230 208 single phase
it just looks like im feeding 1&2 then getting a feed from some sorta switch the 3 and then tying into 1 with that
im just triple checking before i go fryin somthing lol
Old 01-04-2009, 10:50 PM   #9
Electrical Contractor
jbfan's Avatar
Rewards Points: 544
I do not see anything in the drawing that suggest 3 phase.
Is there another drawing?
jbfan is online now   Reply With Quote
Old 01-04-2009, 10:59 PM   #10
yes there is a seperate drawing for 3 phase
Old 01-05-2009, 12:13 AM   #11
nap
You talking to me?
nap's Avatar
all you have to do is remove all the connections that are not in the single phase drawing and add the ones that are and aren;t there now.
the transformer is not used. That is why you need a neutral because the controls are 120 volt.
you will need to rewire all the elements as well as how the power hooks into this in general. The transformer gets deleted. Then look at the area with the fuses. That and the heating elements should be the only changes you need.
It's not difficult but due to having to type every individual step and my inability to see everything real clearly, I would rather answer specific questions than try to tell you everything you need to do.
120/208/1 phase wiring questions JohnJon Electrical 11 08-31-2008 11:28 PM
Laminate wood floor layout questions nathan.tran Flooring 4 08-30-2008 10:56 PM
3 Phase Converter Wiring ideffects Electrical 22 05-26-2008 08:05 PM
3 phase electricity J187 Electrical 11 10-26-2006 01:40 PM
