Old 11-15-2012, 05:07 PM   #1
Special User
1/2HP motor: start on low, or high?
I'll be installing a two-speed (1750/1150RPM) 1/2HP motor in my roof-mounted swamp cooler in the spring. This motor will be controlled by a "smart thermostat" and when the thermostat calls for cooling, it has the option to start in either high or low for a few seconds before switching to the appropriate speed based on cooling demand.
I've noticed that ceiling fans and wall fans usually come with a switch configured for off, high, medium, low. I assume this is deliberate -- by forcing the user to switch to high first, it presumably helps the motor start more reliably. Will a 1/2HP swamp cooler motor benefit from starting on high in the same way, or are they wired differently such it doesn't matter?
An argument for starting on low would be to cause less arcing and wear on the relays (the smart thermostat only switches 24V, separate RIB2401B relays do the heavy lifting), and to help avoid blowing fuses / tripping breakers / dimming lights with a smaller inrush current.
I notice that the typical 6-position swamp cooler dial switch lets you go straight from "off" to "low vent", so this suggests starting on high is not strictly necessary.
Thoughts?
tylernt is offline   Reply With Quote
Old 11-15-2012, 08:47 PM   #2
Missouri Bound's Avatar
Let it start on the low speed and ramp up if needed. I believe that is the purpose of the smart controller.
Do you want it your way or the right way?
The Following User Says Thank You to Missouri Bound For This Useful Post:
tylernt (11-16-2012)
Old 11-15-2012, 09:01 PM   #3
Idiot Emeritus
That type of motor doesn't care in the least which speed it is started on.
I it makes any difference, the transition from low to high will be smoother than from high to low. Other than that, it just doesn't matter.
micromind is offline   Reply With Quote
The Following User Says Thank You to micromind For This Useful Post:
Old 11-16-2012, 12:48 PM   #4
Special User
Awesome, thanks!
does comb. air high and low vent need to be on same wall? windowguy HVAC 2 02-11-2009 12:26 PM
High Hat Install On Old Circuit yellowrubiu Electrical 18 02-04-2009 07:49 PM
high voltage fire alarm jungboklee Electrical 3 01-26-2009 10:07 PM
Old refrigerator = high power consumption? RammsteinNicCage Appliances 6 06-13-2008 11:50 PM
