1-1/4 Inch Rule - Low Voltage - Electrical - DIY Chatroom Home Improvement Forum
Old 04-11-2012, 10:33 PM   #1
Rewards Points: 187
1-1/4 Inch Rule - Low voltage
Hey!
Does the 1-1/4" rule (distance from edge of stud to cable) also apply to low voltage wiring (< 30V)?
I couldn't find anything on the web about this.
Thanks!!
Jaxx is offline   Reply With Quote
Old 04-11-2012, 10:37 PM   #2
Julius793's Avatar
i happen to think not but its stupid not to follow it, also keep in mind that the wire must be rated for inside the wall
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
Old 04-11-2012, 10:41 PM   #3
Rewards Points: 12,856
Why would you not want to follow the rule and take a chance on hitting the wire?
Old 04-11-2012, 10:43 PM   #4
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Agreed...even speaker wire has to be rated to be installed in closed walls.
Old 04-11-2012, 11:49 PM   #5
Rewards Points: 187
Yes agree guys. I have the following problem though.
I have a run of 1" liquitight in a wall from bottom to top along a stud. Now perpendicular I need to run ENT (smurf) which crosses the liquitight. Since the liquitight runs up along the stud it uses the center area where I would put the hole for the ENT. The hole for the ENT now needs to be closer to the edge of the stud. This is in one location and I guess I can just put a nail plate there and I will be golden, right?
Old 04-12-2012, 12:18 AM   #6
Electrical Contractor
kbsparky's Avatar
Right.
-KB
Phantom voltage -- I'm completely stumped kb01 Electrical 2 12-24-2010 07:44 PM
190 185 voltage ? PIGEONS Electrical 10 12-21-2010 12:45 PM
voltage regulation problem - big voltage drop when load applied rnice Electrical 8 12-13-2009 09:43 PM
Low Voltage Post Light b_corwin Landscaping & Lawn Care 1 10-16-2009 10:20 PM
New recessed lighting: Line Voltage vs. low voltage hyunelan2 Electrical 0 10-12-2009 01:25 PM
