Old 01-02-2010, 09:26 PM   #1
Zone Water Valve Problem
So ok, I have two zone water valves from White Rodgers. One is for upstairs and the other one is for the basement. The one in the basement is giving me problems. The thermostats correctly opens them but it looks like it keeps moving them to the close position again because i feel the pipe and it gets hot for a little bit when the valve moves but then it gets cold again after it stops. I tried to manually open them, but it will move them to close again.
So not sure what's going on, please help me out. Thanks
brasilcaps is offline   Reply With Quote
The Following User Says Thank You to brasilcaps For This Useful Post:
1361nut (09-30-2011)
Tags
heating, rodgers, steam, valve, water
Resource for understanding gas valve? darsunt HVAC 19 02-04-2009 12:08 AM
hot water check valve? KE2KB Plumbing 7 01-30-2009 02:36 PM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 06:18 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
