Zone Valves - HVAC - DIY Chatroom Home Improvement Forum
Old 10-12-2009, 06:29 PM   #1
Question
zone valves
i'm going to installing a slant fin gas boiler. should the zone valves go on the supply or the return side....
buck545 is offline   Reply With Quote
Old 10-12-2009, 08:22 PM   #2
GetYourShineBox's Avatar
if you install it on the return side it would be exposed to lower temperatures which would put less stress on the valve.
GetYourShineBox is offline   Reply With Quote
Old 10-12-2009, 08:47 PM   #3
GC/Master Plumber/Mech
Rewards Points: 560
Valve on supply and circulators on the return
Good info on this site
http://www.bellgossett.com/BG-Litera...us-English.asp
Check out Zoning made easy
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 10-13-2009, 06:00 AM   #4
An old Tradesmen
Rewards Points: 6,870
Yep, supply side. If you install them on the return. Some systems will actually gravity heat. By allowing hot water to travel along the top of the supply pipe, and the cold water of the bottom of the supply pipe.
Old 10-13-2009, 05:53 PM   #5
thanks
its been about 20 years since i installed a gas boiler, but i remember a expansion tank with a water fill to fill the boiler. do they make such a thing anymore? i;m just trying to figure out all my parts and locations for a 2 zone system
Old 10-13-2009, 06:50 PM   #6
An old Tradesmen
Fil tro's are still made.
Old 10-14-2009, 04:18 PM   #7
is that the correct spelling for that? i tried googling that part , no such luck
Old 10-14-2009, 04:19 PM   #8
got it.... thanks all
old zone valves from 60's brazin HVAC 3 10-01-2009 01:18 AM
Boiler Zone Purge Valves - Anything special? WaldenL HVAC 4 08-14-2009 08:24 AM
Boiler - Zone Valves Stuck Open djburns HVAC 3 01-12-2009 11:00 PM
