Zone Valve Wiring - HVAC - DIY Chatroom Home Improvement Forum
Old 11-08-2010, 11:06 AM   #1
Zone valve wiring
I need some laymens terms for a zone valve hook up. I put my own unpressurised hydronic heating system for an outdoor boiler. Because the circulator runs constant on the furnace it pushes hot water through my zones. I have decided to use zone valves to stop this unnecesaary heating. My circulators are hookeds to thermostats that are hooked to honeywell transformers (seperate one for each zone). Is ther any way to hook the two yellow and two red to these so I canopen the valve when the circulator turns on? I am general in electrical have done many things but please answer as if I am a blonde and explain things such as end switch etc. Thanks
rocksaranac is offline   Reply With Quote
Old 11-08-2010, 12:53 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 354
Ayuh,... I'm doin' something similar, but different...
If you put Check-valves at the T-stat controlled circulators,... It's stop the ghost heating your gettin'....
I bought Groundfos pump with built-in check-valves...
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Sprikler Valve Wiring? mopowers Landscaping & Lawn Care 3 04-01-2010 10:41 AM
wiring zone valve help paul1968uk Electrical 5 03-31-2010 11:34 AM
How to install thermostatic reactive valve and repack supply valve Leah Frances How To Guides 1 06-10-2009 11:49 AM
Need Replacement Gas Shut Off Value with Side Port for Pilot Light - Photos Available BobN HVAC 12 03-10-2009 01:02 AM
