Zone Valve Question. - HVAC - DIY Chatroom Home Improvement Forum
Old 11-21-2012, 08:31 PM   #1
Zone valve question.
Hello ,
So I have a Pellet Boiler that is piped into my oil boiler that circulates the water. As of right now it is not cold outside but cool enough to keep the heat on. My question is this. DOes anyone see an issue if I leave the 2 zone valves cracked open a little so I dont have the cold water from the 2 zones rushing back to the boilers. The Pellet boiler is cooking all the time which isnt a problem but I wasnt sure if there were any other issues that I should be concerned with....
Thank you ...
stvktchn is offline   Reply With Quote
Old 11-21-2012, 09:53 PM   #2
Rewards Points: 446
The only issue I see is overheating the house possibly. With the zone valves open they will be allowing heat to move from the boilers to the system and into the house.
old_squid is offline   Reply With Quote
Old 11-22-2012, 09:43 AM   #3
The lines that run to the Attic Air Handler run through a chase in the wall and then into the attic.. so I dont think that will be too much of an issue.
Thermostat upgrade on 3 wire hydronic system Greenley77 HVAC 22 11-08-2011 04:47 PM
Honeywell Zone valve problem gnosti83 HVAC 3 01-12-2011 08:55 AM
Zone Valve not working asolarzone HVAC 6 12-12-2010 07:02 AM
Carrier comfort zone II upgrade from comfort zone question detyianni HVAC 3 11-30-2010 01:27 PM
New member, mixing valve question. morrow Plumbing 4 02-25-2010 08:55 PM
