Zone Valve For Hydronic System - HVAC - DIY Chatroom Home Improvement Forum
Old 12-21-2011, 09:06 AM   #1
Zone Valve for Hydronic system
I am adding on to my in floor heating system. I have a large shop which will be on a separate manifold, yes the boiler is sized for this. I am installing Honeywell 24V Zone Valves. My questions is do I use Normally open valves or Normally closed. I am sure either can be made to work but is the a benifit to one over the other? These are installed on the return lines?
screwy is offline   Reply With Quote
Old 12-21-2011, 08:20 PM   #2
Houston204's Avatar
Rewards Points: 556
The benefit of normally closed valves includes more freedom of controls.
24 volts to open is something that any thermostat can provide. This is my preference when piping in high rise heating and chill water valves (on the return pipe).
That said, normally open valves will provide heat if your control fails. This might save your pipes (or toes) from freezing one day should control failure occur.
Houston204 is offline   Reply With Quote
The Following 2 Users Say Thank You to Houston204 For This Useful Post:
ben's plumbing (12-21-2011), screwy (12-24-2011)
Old 12-21-2011, 08:58 PM   #3
Missouri Bound's Avatar
YOu can use the Taco 24v valves which have a handle to open them manually....like a large version of a water heater relief valve.
Old 12-21-2011, 09:03 PM   #4
how
Rewards Points: 1,100
Most honeywell 24V zone valves have levers that can be manually opened and then pulled over to one side to lock into an always open position.
how is offline   Reply With Quote
Old 12-21-2011, 09:07 PM   #5
Thanks for the info.
I haven't used those, our supplier has Taco only.
Old 12-21-2011, 09:18 PM   #6
Houston204's Avatar
Rewards Points: 556
Erie and Belimo can also have this lever to manually open the valve.
Most control valves can be manually opened.
Thermostat upgrade on 3 wire hydronic system Greenley77 HVAC 22 11-08-2011 05:47 PM
Need advice RE: purging air from baseboard hot water heating system mikenri HVAC 2 01-19-2011 08:17 PM
Permit For Fire Sprinklers letnes Plumbing 18 10-14-2010 06:23 PM
Help w/ mixing valve (I think) ink HVAC 15 02-28-2010 11:01 PM
Leaking pressure relief valve Chris Magee Plumbing 12 08-12-2008 08:48 PM
