Old 07-21-2007, 08:03 PM   #1
Zone Valve change motor
Hi
My zone valve has stopped working, I have bought (on good advise) a new synchronous motor and have been told that a straight replacement would solve the problem.
Has anyone ever changed one of these motors and is it a DIY job.
I would be glad of any advise
jim
jim99 is offline   Reply With Quote
Old 07-21-2007, 09:55 PM   #2
Mechanical Contractor
It depends on what type of valve it is. Honeywell and Erie motors are easily changed out, two small phillips head screws hold the motor in place, then it just two wire nuts.
MechanicalDVR is offline   Reply With Quote
Old 07-22-2007, 07:37 AM   #3
Hi
Thank you for the advise, it’s a Honeywell.
I did a google search and found a website
http://www.grahamvideos.co.uk they have a video for download that demonstrates the job from start to finish.
As you correctly said ‘two screws - two wires’ job done.
About two weeks ago I had a quote from a plumber, you wouldn’t believe what he said it would cost..!
Once again thank you for your help
jim99
ball valve leaking bwall Plumbing 10 12-31-2012 08:25 PM
Toilet valve replacement? steve771 Plumbing 18 07-10-2007 11:50 AM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 03:17 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
