Zone System Retrofit Possible? - HVAC - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 03:40 PM   #1
perpetualjon's Avatar
Rewards Points: 150
Zone system retrofit possible?
I have a 1600sf home with a roof-mounted central air unit that I've had to gut all the duct work and now have a completely exposed unit (in essence, a "blank canvass") to re-do my duct work. I was planning on well-sealed / insulated work but I've been wondering if it is possible to implement a "zone system" into this unit since I now have all the access I'd ever need. I'm thinking I'd like to heat / cool the bedrooms at night but not the large living space and vice-versa during the day.
My thinking is that it may not work because of several problems:
1. I'd need two different thermostats so that the unit will know when it's attained the proper temp in each zone --and running the unit to cool BOTH zones may also pose a problem as the two thermostats would argue with each other.
2. I will need individual returns from each zone.
3. Since the unit is designed for the entire house, it may be over-sized for the smaller zone system.
Still, I hate the fact that I'm rarely needing to heat / cool the entire house all at once! Now, I can close the registers to each bedroom and just cover the front living spaces since the thermostat is in a central location there but that still doesn't solve the problem of what to do when we all go to bed!
Any ideas or am I just going to have to settle for what I have?
"...and everyone is entitled to my opinion!!"
Read more about my ongoing remodeling project
perpetualjon is offline   Reply With Quote
Old 07-14-2010, 06:18 PM   #2
An old Tradesmen
Rewards Points: 6,576
You need a zone control system.
It will comprise 2 thermostats, 2 motorized dampers, and 1 barometric bypass damper.
I'd suggest the Honeywell Envirozone panel.
Old 07-14-2010, 06:23 PM   #3
Rewards Points: 150
Awesome! Thanks for the help!!
help with zonex dual zone system bman1968 HVAC 2 06-06-2012 03:38 PM
No heat in one zone: Need help bleeding system dvsrikanth HVAC 0 04-01-2010 09:55 AM
Adding new zone makapacs HVAC 0 11-26-2009 01:35 PM
no ciculation in one zone of forced water heating system srossdiy Plumbing 2 01-27-2009 11:39 PM
Zone system not working with heat. deliriousga HVAC 5 12-29-2006 07:04 PM
