Old 12-29-2006, 04:52 PM   #1
Zone system not working with heat.
I have a 4 zone controller (RCS Model ZC4) with three zones currently set up. My HVAC system is a standard forced air Heating-A/C system (no heat pump). There are 3 RiteTemp 8050 thermostats connected to the controller and a single 12" damper on each zone. The system works perfectly with A/C, but it's giving me trouble with the heat.
I can connect everything and the system runs for a few days, but then it quits. None of the thermostats will start the heat until I remove the wiring and then reconnect everything. I can bypass the zone controller by connecting one of the thermostats to the HVAC wires and it works without zoning so I know it's not the HVAC system.
Has anyone experienced this and/or have any ideas of where to go next?
TIA!
deliriousga is offline   Reply With Quote
Old 12-29-2006, 04:57 PM   #2
Your zone control is going into lock out mode...........as far as why, well thats anyones guess.
acefurnacefixer is offline   Reply With Quote
Old 12-29-2006, 05:13 PM   #3
I've been reading about putting in a "dump zone" to keep from creating back pressure when only one zone is open. I don't have one so is that something that would cause a zone controller to go into lock out mode? I can add one pretty easily in a room we don't use if needed.
Old 12-29-2006, 05:22 PM   #4
How old is the system?
redline is offline   Reply With Quote
Old 12-29-2006, 05:26 PM   #5
The house was built in '96. It's a Ruud system (2 ton I think). The same system is on the third floor with one thermostat and no problems. Since I'm finishing the basement, I added ducts and put the zone in to help even out the air flow.
Old 12-29-2006, 07:04 PM   #6
does your zone control panel have a light that blinks any codes or stays on. the zone controler is most likely locking out.next time it goes out try reseting the power to the damper system and see if that restarts it. remember to get the flashing codes first if your zone controler has a led.
trollmastergeneral is offline   Reply With Quote
gurgling in baseboard heat system jpg HVAC 1 02-22-2007 07:56 PM
Wiring of my two-zone system not working correctly AMontemagni HVAC 3 01-27-2007 01:07 PM
heat pump not working kyleGR HVAC 2 05-30-2006 03:35 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 06:47 PM
